Finding the Perfect Hidden Door/Window Sensors
I’ve been on a mission to find the best hidden door and window sensors for my smart home setup. After some research and trial, I’d like to share my experience and recommendations.
The Challenge:
My windows and doors are triple-glazed, which means I need sensors that are extremely slim—max 29mm wide and around 12mm thick. The Shelly BLU DW was an option, but it’s a bit too bulky for my setup. Plus, it’s not Z-Wave, which is a deal-breaker for me since I’m using Home Assistant.
The Solution:
After some digging, I found a few Z-Wave sensors that fit the bill. The Aqara Door/Window Sensor (Magnetic) was a top contender. It’s incredibly slim and blends seamlessly into my window frames. Plus, it’s fully compatible with Z-Wave and integrates smoothly with Home Assistant.
Another great option I stumbled upon is the EcoProducts Door/Window Sensor. It’s slightly thicker than the Aqara but still within my size constraints. What I love about this sensor is its reliability—it’s been consistently detecting door movements without any issues.
Installation Tips:
  • Placement: Make sure to place the sensors as close as possible to ensure a strong magnetic connection. I found that a gap of less than 5mm works best.
  • Alignment: Proper alignment is key. I used a small ruler to ensure both the sensor and magnet were perfectly aligned.
  • Testing: After installation, I ran a quick test by opening and closing the door several times to ensure the sensor was working as expected.
Why These Sensors Stand Out:
  • Discreet Design: Both sensors are practically invisible once installed, which is perfect for maintaining the aesthetic of my home.
  • Reliability: I’ve had zero false positives or missed detections, which is crucial for a seamless smart home experience.
  • Compatibility: Being Z-Wave compatible means they work flawlessly with my existing setup in Home Assistant.
If you’re in the market for hidden door or window sensors, I highly recommend checking out these options. They’ve been a game-changer for my smart home setup! :house_with_garden::sparkles:
