After years of using various robot vacuums, including models from Neato and Eufy, I’m excited to share my initial impressions of the Wyze Vacuum. As someone who’s always looking for reliable, budget-friendly solutions, I jumped at the chance to test this unit through the WyzeBeta program.
Design and Build Quality
The Wyze Vacuum is slightly larger and heavier than my current Eufy models, which isn’t a bad thing—it feels sturdy and well-built. I appreciate the rotating sweeper arm, which seems to do a great job of picking up debris. The dust bin is larger than the Eufy 11slim and has a plastic seal, which I hope will reduce the hassle of cleaning and maintenance.
Performance and Navigation
From the first run, I was impressed by how quickly the vacuum mapped my open-layout home. It successfully navigated around furniture and obstacles, including a rowing machine I left in the living room. The vacuum’s ability to handle dog hair and dander was particularly notable—it collected far more dander than my other units, which I attribute to the larger dust bin and the fact that it’s brand new with fresh filters.
Battery Life and Charging
On the strong suction setting, the vacuum ran for 1.2 hours before needing to return to the charging base. However, I did experience some issues with the return process, as the vacuum seemed confused and needed manual assistance. I’m hopeful this will improve with continued use.
Initial Thoughts and Conclusion
While there are a few minor hiccups, like the slight static shock when emptying the dust bin and the occasional navigation issue, the Wyze Vacuum has made a strong first impression. At the $199.99 price point, it’s a compelling option for anyone looking for a reliable, budget-friendly robot vacuum. I’m eager to see how it performs over the long term and would definitely recommend it to others looking for a capable cleaning solution.
Overall, I’m thrilled with my purchase and look forward to seeing how the Wyze Vacuum holds up in the coming months. If you’re in the market for a new robot vacuum, this one is definitely worth considering!
