Fixing Google WiFi Blue Light Issue After Factory Reset
Hey everyone, I wanted to share a solution I found for a frustrating issue with my Google WiFi device. After performing a factory reset on one of my units, it kept showing a steady blue light instead of connecting properly. I tried resetting it multiple times, but the problem persisted. After some research, I discovered that the issue might be related to the device’s firmware or a conflict with other devices on the network. Here’s what I did to resolve it:1. Unplug and Reset: I unplugged the device, waited for 30 seconds, and then plugged it back in. I held down the reset button for 10 seconds until the light started blinking.2. Check for Firmware Updates: I opened the Google Home app and checked for any available firmware updates for the device.3. Reboot the Hub: I also restarted my main Google WiFi hub to ensure everything was communicating properly.4. Factory Reset Again: After the firmware update, I performed another factory reset on the problematic device.This time, the device connected successfully, and the blue light issue was resolved. It was a bit of a hassle, but persistence paid off! If anyone else is experiencing similar issues, I hope this helps. Let me know if you have any questions or alternative solutions. :blush:
