I recently added a Wyze Floodlight Extra Camera to my setup, and it’s been a fantastic addition for security and monitoring. However, I’ve encountered an issue where the camera goes offline periodically, which has been quite frustrating. After some research and troubleshooting, I wanted to share my experience and some tips that might help others facing similar issues.
My Experience:
I installed the camera a few months ago, and it worked flawlessly for the first couple of weeks. The night vision is excellent, and the motion detection is very accurate. However, about a month ago, the camera started going offline sporadically. I tried the usual troubleshooting steps—rebooting the camera, checking the Wi-Fi connection, and ensuring the firmware was up to date. For a while, these steps seemed to resolve the issue, but it kept recurring.
What I Did Next:
After some digging, I found that others were experiencing similar issues, particularly with firmware versions around 4.36.3.19. I decided to reach out to Wyze support directly. They were very responsive and suggested a factory reset and a clean install of the latest firmware. This process involved removing the camera from the Wyze app, performing a factory reset, and then reinstalling it as a new device. Surprisingly, this seemed to do the trick!
Tips for Others:
- Firmware Updates: Always ensure your camera is running the latest firmware. Wyze frequently releases updates that improve stability and performance.
- Network Stability: Check your Wi-Fi signal strength near the camera. Weak signals can cause connectivity issues. Consider using a Wi-Fi extender if necessary.
- Regular Maintenance: Periodically check the camera’s status in the app and reboot it if you notice any irregular behavior.
- Contact Support: If issues persist, don’t hesitate to contact Wyze support. They’ve been very helpful in my experience.
Conclusion:
While the offline issues were a bit of a setback, the Floodlight Extra Camera remains a valuable addition to my smart home setup. With a little troubleshooting and the right support, it’s back to performing like a champ. I hope these tips help others who might be experiencing similar problems. Happy smart home hacking! ![]()
