Hey all! I had a chance to try out the Floor Lamp T1 for a few weeks now and wanted to share the before and after. I’m loving it!
Before:
After:
It really helps to tie up the entertainment area of the humble little apartment.
The lamp is well built and setup was easy! I connected it to the Aqara App via Threads (I don’t have Aqara Hub), and from there I shared the Threads connection to add it to Home Assistant.
At this point I have quite a few Aqara devices (FP300, FP400, plugs, etc). The process was smooth!
One thing I lose with this approach is not being able to configure light sections directly in Home Assistant, but it’s reliable with all my other automations. I use a basic automation with Adaptive Lighting, so the floor lamp turns on/off with all other lights in the room and follow a brightness+temperature curve with the time of day.
I also played around with the features directly in the Aqara app. The music sensor was surprisingly good!
My favorite:
- The light can get bright, the colors are very vivid, and it diffuses incredibly well on the wall!
Wish it was better:
- One main thing I wish it had was a better “Candle” light effect that replicates an actual candle. There is a “Candle” effect in the Aqara app, but it doesn’t behave the way I would expect when I think of a candle. It has a white light in the middle, then expands in/out from the center to the color you choose. There isn’t a way to have an all warm/orange glow that flickers like a candle.
Overall, I continue to be impressed with the products that Aqara puts out, and love the interoperability with Home Assistant!
