Fo2 loses people sitting on couch
The sensor is “behind” the couch, and it sees people go to the couch, but then they disappear……
I suspect the location you’ve chosen for the sensor is simply too difficult. If possible, place the sensor somewhere else. If you want to monitor the couch, I recommend placing the sensor opposite it in a corner. The sensor works best when installed at a height between 1.40 and 1.80 meters.
You can try to adjust the sensitivity to be hight for the couch area
