Fp2 does not export illumination to Google home
Did anyone managed to see the illumination info from the FP2 sensor that appears in the aqara app, to be seen in Google home?
In my installation of FP2 and integration with Google home it also does not show illuminance. Maybe it is not supported.
It is exported to IFTTT
This blocks a comment use case of turning on lights , when natural light is dim.
Aqara chat claims that google home does not support the option of the same presense sensor to also report illumination as in Ifttt.
But, even if you try to setup an applet in Ifttt that will turn-on the light if: a zone is entered and the illumination is below 50 lux. It only allows one condition.
A workaround is to find the automation it creates in my aqara, and edit it to trigger only when illumination is below a given value.
May be simpler done.
