FP2 Ghosting feature request
Please consider an opt in presence clear feature if a threshold of movement hasn’t been met within a time frame for each tracked presence. I’m constantly having to manually remove ghosting and they stay completely still so this feature should allow them to clear themselves instead of me having to manually clear them for my automations to turn my lights off. If I’m still in the room it should pick me back up as I have some sort of movement vs the ghost. Also when manually removing it’s annoying to remove as it’s almost as though the presence icons glitch through the sticker layout and I have to tap it several times to try and get the manual remove option to appear.
@germexican Your suggestion for an opt-in presence clear feature to address ghosting in the FP2 is quite insightful! It seems that having a system where the presence is automatically cleared if a movement threshold isn’t met could indeed streamline automations, like turning lights off without manual intervention. This would definitely enhance the user experience by ensuring that the system recognizes actual presence versus ghosting.
Regarding the difficulty in manually removing ghosting due to the icons glitching through the sticker layout, it’s understandable how this can be frustrating. While current documentation doesn’t specifically address this feature or issue, your feedback is valuable and could inspire improvements in future updates.
Let’s keep the conversation going in the community to see if others have found workarounds or share similar experiences. Your input is crucial for driving enhancements in smart home solutions!
I support this feature request
How do I know my idea will be seen by the team for consideration? Is there a better place to post it? As a work around I just created a shortcut called reset ghost which removes presence all together. This isn’t ideal as I have to always hit it when I leave my automation area but I at least know the lights will turn off and I don’t have to remove the ghosts by hand.
@germexican Your concern about ensuring that your idea is seen by the Aqara team is completely understandable. While this forum is a great place for sharing ideas and gathering community feedback, I recommend also submitting your suggestion directly through the Aqara Home App. You can contact the Customer Service Team via the app under Profile > Help & Feedback > Customer Service. Alternatively, you can scan the QR code:
This method ensures your feedback reaches the right channels for consideration in future updates. It’s great that you’ve found a workaround with the reset ghost shortcut, though I understand it’s not the perfect solution. Your proactive approach is commendable, and your feedback is valuable for improving the overall experience for all users. Let’s keep the discussion alive here to see if others have additional insights or solutions!
