FP2 Homekit automation
Thanks for the replies.
Spot on @coletti.robert I did it in EVE app.
I have done more testing and suspect the lux reading variance exceeded the condition when it happened.
I set it to less than 16 lux above but the FP2 sometimes returns higher lux even I think there is no change in the room during daylight. I will see if I can somehow get it showing in the log of the homecare app.
The same lux values can feel different (in the morning and evening for example) because of how our eyes perceive light color and direction. So, even with identical lux readings, the impression can vary. Or the other way around: the impression is the same, while the lux reading changes.
For this reason, I created two automations at different times.
  • Between 00:00 and 12:00 → if the light level is below 20 lux
  • Between 12:00 and 00:00 → if the light level is below 30 lux
Is it possible to set action times in the Eve app? I implemented this using the Aqara Home app.
