FP2 loses presence when a second person enters and leaves
When one person is already in the room and a second person walks in and then leaves again, the FP2 sometimes reports the room as empty, even though the first person never left or if two people sit next to each other sometimes they get merged.
Questions
• Known limitation of the multi-target algorithm, or fixable via firmware?
• Any zone/sensitivity settings that reduce merge/re-assignment errors specifically?
• Workarounds?
@Expert Could anyone check this?
Normally it should work… but what shows the live map? Where is the sensor mounted? Which height? More infos needed for a proper help
Unfortunately I have those problems too, especially if two people are sitting on the couch and one leaves.
Try lowering the sensitivity in some zones. Higher sensitivity does not always mean “hey, FP2, try looking for people INTENSIVELY”, it boosts power (which means it also gets more interference/noise) and processing/interpretation algorithms of those zones. Which means that the sensor will detect (and try to ignore) more false positives. In this case, the anti-interference algorithm kicks in and removes presence (when the sensor is unsure of the signal).
I haven’t had that problem yet. I have the “AI Person Detection” option turned off. It might be worth a try.
I have experienced this as well. I have AI person detection disabled because I was having some other issues with that. I have mine mounted about 7’/2M high near the corner of my room. Based on advice given I have lowered the sensitivity in this zone and will report back.
New update for the FP2 I hope Aqara solved some of the issues we had with it
Changing the sensitivity seems to have helped slightly, but it still happens more than enough to annoy my wife. I also tried re-enabling AI person detection and that didn’t seem to make any difference.
I just updated my firmware today, so I will keep trying things.
Welcome to the forum @kaa246 !
