Fp300 firmware update fail
I can not update the firmware. It’s shows 3% in updating then Keeps failing. It’s on zigbee protocol. I did the basic troubleshooting. Please help
The Zigbee update may be really slow unfortunately.
Have you tried clicking the FP300 button before clicking update?
Have you tried restarting your hub, then clicking the button (after the hub is live again), then clicking update?
Hi, I also had this issue- it helped to change to Matter first and switching later back to Zigbee - then the App uploaded the latest Zigbee firmware to it. Not the best option- but it worked
Hi, welcome to the forum.
Personally, placing the sensor near the gateway at the time of the update helped me
When pressing the button on the device didn’t help I did it the same way as @DEChrisE said. That’s a 100% success for me
Didn’t helped me too… seems there’s some problem
Hi @cefgaray3_security - could you solve it?
Thank you so much. It’s now updated
Great :+1: unfortunately it’s definitely not the best and logical way to update! Hope for improvement there
When a firmware update got stuck here, taking the batteries out for a few minutes and letting the sensor reset was what fixed it. After that the update went through normally.
I run mine on Zigbee throughout and have only switched protocols once, from Matter to Zigbee, right after buying them.
