I found another consistent difference between a healthy join and the failure that occurs after ~24 hours.
During the initial join, the Trust Center key exchange completes successfully with TC_REQUESTER_VERIFY_KEY_SUCCESS.
In the failing scenario, the Trust Center responds to the key request (TC_RESPONDED_TO_KEY_REQUEST), but TC_REQUESTER_VERIFY_KEY_SUCCESS never follows.
After this event, the FP300 remains connected to the network, and explicit attribute reads still work, but the device enters the partially broken state I described in my previous post. Only attributes with reporting explicitly configured by ZHA continue to report.
In runs where this later key exchange does not occur, the FP300 continues to operate normally.
Here are the log sequences captured immediately before the FP300 enters this broken state:
log 1
2026-09-22 16:37:23.185 DEBUG (MainThread) [bellows.ezsp.protocol] Received command incomingMessageHandler: {'type': <EmberIncomingMessageType.INCOMING_UNICAST: 0>, 'apsFrame': EmberApsFrame(profileId=0, clusterId=2, sourceEndpoint=0, destinationEndpoint=0, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=76), 'lastHopLqi': 140, 'lastHopRssi': -65, 'sender': 0xB52E, 'bindingIndex': 255, 'addressIndex': 255, 'messageContents': b'\x84\x00\x00'}
2026-09-22 16:37:23.185 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=0, clusterId=2, sourceEndpoint=0, destinationEndpoint=0, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=76), 140, -65, 0xB52E, 255, 255, b'\x84\x00\x00']
2026-09-22 16:37:23.186 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2026, 9, 22, 13, 37, 23, 186331, tzinfo=datetime.timezone.utc), priority=None, src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xB52E), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=76, profile_id=0, cluster_id=2, data=Serialized[b'\x84\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=140, rssi=-65)
2026-09-22 16:37:23.187 DEBUG (MainThread) [zigpy.zdo] [0xb52e:zdo] ZDO request ZDOCmd.Node_Desc_req: [0x0000]
2026-09-22 16:37:23.187 DEBUG (MainThread) [zigpy.zdo] [0xb52e:zdo] No handler for ZDO request:ZDOCmd.Node_Desc_req([0x0000])
2026-09-22 16:37:24.021 DEBUG (MainThread) [bellows.ezsp.protocol] Received command zigbeeKeyEstablishmentHandler: {'partner': 54:ef:44:10:01:33:d0:1f, 'status': <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>}
2026-09-22 16:37:24.021 DEBUG (MainThread) [bellows.zigbee.application] Received zigbeeKeyEstablishmentHandler frame with [54:ef:44:10:01:33:d0:1f, <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>]
log 2
2026-09-25 12:14:29.678 DEBUG (MainThread) [bellows.ezsp.protocol] Received command incomingMessageHandler: {'type': <EmberIncomingMessageType.INCOMING_UNICAST: 0>, 'apsFrame': EmberApsFrame(profileId=0, clusterId=2, sourceEndpoint=0, destinationEndpoint=0, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=14), 'lastHopLqi': 156, 'lastHopRssi': -61, 'sender': 0x6F9E, 'bindingIndex': 255, 'addressIndex': 255, 'messageContents': b'\x83\x00\x00'}
2026-09-25 12:14:29.679 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=0, clusterId=2, sourceEndpoint=0, destinationEndpoint=0, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=14), 156, -61, 0x6F9E, 255, 255, b'\x83\x00\x00']
2026-09-25 12:14:29.679 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2026, 9, 25, 9, 14, 29, 679774, tzinfo=datetime.timezone.utc), priority=None, src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x6F9E), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=14, profile_id=0, cluster_id=2, data=Serialized[b'\x83\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=156, rssi=-61)
2026-09-25 12:14:29.681 DEBUG (MainThread) [zigpy.zdo] [0x6f9e:zdo] ZDO request ZDOCmd.Node_Desc_req: [0x0000]
2026-09-25 12:14:29.681 DEBUG (MainThread) [zigpy.zdo] [0x6f9e:zdo] No handler for ZDO request:ZDOCmd.Node_Desc_req([0x0000])
2026-09-25 12:14:30.730 DEBUG (MainThread) [bellows.ezsp.protocol] Received command zigbeeKeyEstablishmentHandler: {'partner': 54:ef:44:10:01:33:d0:1f, 'status': <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>}
2026-09-25 12:14:30.730 DEBUG (MainThread) [bellows.zigbee.application] Received zigbeeKeyEstablishmentHandler frame with [54:ef:44:10:01:33:d0:1f, <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>]
2026-09-25 12:14:38.329 DEBUG (MainThread) [bellows.ezsp.protocol] Received command incomingRouteErrorHandler: {'status': <EmberStatus.MAC_INDIRECT_TIMEOUT: 66>, 'target': 0x6F9E}
2026-09-25 12:14:38.329 DEBUG (MainThread) [bellows.zigbee.application] Received incomingRouteErrorHandler frame with [<EmberStatus.MAC_INDIRECT_TIMEOUT: 66>, 0x6F9E]
2026-09-25 12:14:38.330 DEBUG (MainThread) [bellows.zigbee.application] Processing route error: status=sl_Status.MAC_INDIRECT_TIMEOUT, nwk=0x6F9E
2026-09-25 12:14:42.249 DEBUG (MainThread) [bellows.ezsp.protocol] Received command zigbeeKeyEstablishmentHandler: {'partner': 54:ef:44:10:01:33:d0:1f, 'status': <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>}
2026-09-25 12:14:42.249 DEBUG (MainThread) [bellows.zigbee.application] Received zigbeeKeyEstablishmentHandler frame with [54:ef:44:10:01:33:d0:1f, <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>]
2026-09-25 12:14:49.849 DEBUG (MainThread) [bellows.ezsp.protocol] Received command incomingRouteErrorHandler: {'status': <EmberStatus.MAC_INDIRECT_TIMEOUT: 66>, 'target': 0x6F9E}
2026-09-25 12:14:49.850 DEBUG (MainThread) [bellows.zigbee.application] Received incomingRouteErrorHandler frame with [<EmberStatus.MAC_INDIRECT_TIMEOUT: 66>, 0x6F9E]
2026-09-25 12:14:49.850 DEBUG (MainThread) [bellows.zigbee.application] Processing route error: status=sl_Status.MAC_INDIRECT_TIMEOUT, nwk=0x6F9E
2026-09-25 12:14:56.531 DEBUG (MainThread) [bellows.ezsp.protocol] Received command zigbeeKeyEstablishmentHandler: {'partner': 54:ef:44:10:01:33:d0:1f, 'status': <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>}
2026-09-25 12:14:56.531 DEBUG (MainThread) [bellows.zigbee.application] Received zigbeeKeyEstablishmentHandler frame with [54:ef:44:10:01:33:d0:1f, <EmberKeyStatus.TC_RESPONDED_TO_KEY_REQUEST: 6>]
2026-09-25 12:15:04.131 DEBUG (MainThread) [bellows.ezsp.protocol] Received command incomingRouteErrorHandler: {'status': <EmberStatus.MAC_INDIRECT_TIMEOUT: 66>, 'target': 0x6F9E}
2026-09-25 12:15:04.131 DEBUG (MainThread) [bellows.zigbee.application] Received incomingRouteErrorHandler frame with [<EmberStatus.MAC_INDIRECT_TIMEOUT: 66>, 0x6F9E]
2026-09-25 12:15:04.131 DEBUG (MainThread) [bellows.zigbee.application] Processing route error: status=sl_Status.MAC_INDIRECT_TIMEOUT, nwk=0x6F9E
