FP300 stops working
So I ordered the FP300 from Amazon the first day it was available. It’s working nicely for about two weeks in Thread mode in Home Assistant via Matter. Then it became unavailable in Home Assistant. I re-paired it and it worked again for two days. Now it stopped again. What can I do?
I believe Thread is pretty scetchy on it from what others have been saying with limited function …use the ZigBee protocol and you’ll probably have better luck with more functionality
I will try Zigbee for now, but my Thread network has much better coverage and therefore is usually faster to react
I also recommend to change to zigbee! And the Fp300 has much more efforts in Zigbee mode - Special in The Aqara App!
Give it a try :x2fozabcpx9xrbxmdpseb3_61:
Actually I bought this because this is marketed as Matter-over-Thread. If it doesnt work in Thread mode I will send it back.
I totally agree I am trying to migrate devices to thread and the FP300 is supposed to be battery and thread human presence with temp and humidity. So It is very frustrating it is not working. I have ordered several Meross MS605 to try as well.
What is the phenomenon when the device is not working?
In Home Assistant every entity is unavailable.
Hello, we attach great importance to the question you mentioned. What version of Home Assistant do you use? Can you share the specific usage process and error description in more detail?
Do you have any similar problems with other thread devices in Home Assistant?
I’m having the same problem. Bought four from two different retailers.
The logs are showing me that the ZBT-2 / OpenThread Border Router keeps getting errors.
Beelink Mini PC EQ14 (HAOS)
ZBT - OpenThread RCP 2.4.4.0
Core 2026.1.3
Supervisor 2026.01.1
Operating System 17.0
Frontend 20260107.2
Update. I installed the beta firmware for the ZBT-2 and the past 24 hours seem to have gone well.
It’s able to recover the device if it fails, so it does’t stop working.
Beta firmware: 2.7.2.0
Haven’t run into other issues with the beta.
Same issue here. FP300 over thread stopped working after 3 days with Apple TV 4K acting as a border router. I managed to reset it and got it working again for some weeks, but since yesterday it is not connected in Apple Home or Home Assistant anymore :frowning:
Hi, do you have another border router except Apple TV ? Would be good to try and see if the issue happen with this border router. And it is suggested to upgrade all to the latest version.
Got 3 Aqara FP300 and All of them stops working in Apple Home or Home Assistant. They run Fine two weeks und then „unavailable“ in Home Assistant.
I have a Apple HomePod mini and several Eve Energy transmitter. My Thread Network Runs absolutely Fine except Aqara FP300.
They run unavailable the third Time. I wish i could Return them.
If you aren’t running the beta OTBR, may I suggest trying that.
I had disconnect issues as well but once I switched to the beta the issues disappeared.
Adding a data point and a request for Aqara to investigate the FP300’s Thread behavior.
My setup: Two FP300s on latest firmware, both going unavailable together for hours to days. Battery 100%, rest of my Matter/Thread fleet fine. Only a battery pull recovers them — waking the sensors or restarting Matter Server does nothing.
Worth distinguishing two failure modes in this thread:
  1. OTBR-side instability — VesNL’s case, resolved by the ZBT-2 beta (2.7.2.0).
  2. FP300-side reattach failure — what I’m seeing, and likely what Nils and shukuyen are hitting too (healthy Apple TV / HomePod networks otherwise).
In my case, decoding the Thread mesh-local addresses showed both FP300s parented to the same router that briefly dropped off Thread. The router recovered on its own; the FP300s stayed orphaned for a full day despite a router-rich mesh with multiple viable parents in range (−16 to −32 dBm). The redundancy was there; the sensors didn’t use it.
The pattern across the thread: works ~2 weeks, then unavailable. Multiple users, multiple border router stacks (OTBR, Apple TV, HomePod). Only re-pair or battery pull recovers. Other Thread devices on the same networks are unaffected. When the same failure shows up across different border routers, the common factor is the FP300.
Request to Aqara (@MakerMing): Could the team look at the FP300’s parent-loss recovery? Symptoms are consistent with a sleepy end device that isn’t aggressively re-acquiring a parent — long reattach backoff, infrequent parent search. Specifically:
  1. Can you confirm the current reattach / parent-search parameters in shipping firmware?
  2. Is a firmware update planned to make parent re-selection more aggressive? Thread mesh redundancy is a core selling point for a Matter-over-Thread sensor.
  3. Is there a better diagnostic path than “re-pair” or “pull the battery”?
Happy to share RLOC16 decoding, timeline, and signal-strength data if useful.
For others: in the meantime, check what Thread router your FP300 is parented to — if it’s flaky then thats the current issue but the sensor SHOULD find a new parent but it doesnt.
