FP400 Level issue
So, excited because I got my FP400 today!
BUT…
During setup, I captured the QR code, chose Thread, and it takes me to the setup task (just like the FP2 did). Now I like to think I’m a pretty level-headed guy but here’s what I get:
Now, I’ve done this before with my FP2. Here’s a pic of my new FP400:
I repaired and tried again - twice!
Still get the same error. Any advice???
Edit to add: I also power cycled…
Well my be try factory reset it and then try again
Okay, I’ll get my clicking finger ready…
No joy. But I did repair it for a 3rd time. Same problem.
How did you?as I never encounter that error and I had to reset it 3 tienes since I got it 2 times to try each zigbee and thread and the 3th time is because I delete all my apple home and being as thread it delete it from Aqara too as I still need to figure it out what device makes apple home app draining during the night
Well? Since you followed the instructions and nothing has worked it’s time to go old school and install using “common sense” and no instructions.
Remove the FP400 from the wall and set it on a table in front of you.
Close out the Aqara app on the phone. Reset the FP400 again
Power up the FP400 and open up the Aqara app, choose Accessories and tap the + (top right corner) or if it’s detected at the top of the screen choose that. Install using Zigbee as the protocol.
Forget Apple Home or HA for the moment. See if you can get it to play nice with just the Aqara app.
Okay, I’ll try anything. BTW, all I’m using so far is the Aqara app. Keeping things simple. I’ll report back…
Okay, I switched the mode to Zigbee and it all worked (don’t know why). The software transfer and mode changeover takes a while.
I had planned on later switching back to Thread but see that that requires removing and reinstalling. Not today.
Anyway, thanks to both of you for your suggestions.
Edit to add: Since corner install is recommended, I’m surprised Aqara doesn’t make the bracket to pivot for a corner install, but instead offers a corner mount bracket as an option.
I have try both ways and yes take some good amount of minutes to install the version you want to set it :rofl::rofl::rofl: more when I update it via thread was even longer time :rofl::rofl:
It sounds more like encountering an unlikely and unknown hardware failure. If the after-sales service is already handling it, the recommended course of action is to simply replace the device and send it back for analysis.
@ming_wen that’s my assessment as well, although I do wonder what sort of hardware would fail under one protocol but succeed on another. I’ll be happy to do whatever helps.
