FP400 - my experiences as a mmWave newbie
I was selected to order my FP400 at a discounted price a few weeks ahead of the UK launch.
This is my first mmWave presence sensor, so please consider my experiences as part of the learning process.
The set up process of connection an Aqara device to an Aqara hub was straightforward as usual, however for me the ZigBee firmware took around 1 hour to download on my Android phone. I raised this with the team at Aqara, and have not yet read of others experiencing this issue.
After setup, I had the challenge of where to install the sensor and how to power it. The room I require presence detection is living/kitchen space with 2 zones to monitor. We live in a 1960s house of solid “cinder block” construction From experience, WiFi & 2.4Ghz signals are attenuated and I expected the mmWave to be similarly impacted by solid wall blind spots, as well as our gigantic fridge freezer. There are no useable corners in this space due to doors, windows and wall cupboards.
The main zone to monitor is the kitchen, so I first mounted the sensor there for the best view of that zone.
The app guides the user through the install. I placed the sensor in the best available kitchen location on top of the wall cupboards, aware that this was higher than the app recommends. I completed the mapping and after living with the FP400 in this location for a few days, I found that the sensor being mounted too high meant that seated people in the living zone were not being detected.
I next mounted the sensor at the opposite end of the room, in the living area. Again this position is less than ideal as exits/entrances to the room are obscured from the sensor by solid walls. I next made the mistake of manually adding what I considered to be “interference” sources to the area. This turned out to be a mistake as detected people would disappear or remain as “ghosts” if they stood near that “interference” for any length of time.
The issue with blind spots around the doorways means that people leaving the room would be detected as standing in the corner and never leaving. I found that I can long-press these “ghosts” in the FP400 and delete them, which added an “interference” source to that square.
My experience has been frustrated by the environment, routing USB power to the the FP400, as much as the required learning curve of an advanced mmWave sensor. Having said that, I have been successfully using presence detection for automatically changing the brightness of lights & triggering nighttime routines. The more I spend getting to know the capabilities and limitations of the FP400 in this living space, the more I feel I can trust the presence detection which is only improving with time.
@_Mevi Thanks for sharing your detailed FP400 journey—this is exactly the kind of real-world experience that helps the whole community learn! Your honest breakdown of the trial-and-error process is super valuable, especially for fellow mmWave newbies navigating tricky installs.
A few thoughts on your setup challenges:
Mounting height – You nailed the key issue here. For wall or corner mounting, the recommended height is typically 1.4–1.8m (or ~2m if you need wider coverage). Going too high definitely creates blind spots for seated people, as you discovered. The cinder block construction and lack of usable corners is genuinely tough—those solid walls are unforgiving for both RF and mmWave propagation.
“Interference” sources & ghosts – This is a really common learning curve moment! Interference sources are meant for non-human moving objects like fans, curtains, or plants that emit weaker signals. When you mark areas where actual people stand, the sensor gets confused—exactly the “disappearing or ghosting” behavior you described. Your workaround of long-pressing ghosts to delete them is spot-on, and that auto-added interference square is a nice unintended feature.
Blind spots around doorways – Since you can’t relocate walls, have you tried configuring edges and exits more aggressively? Defining the maximum detection boundary and properly marking entry/exit paths helps the sensor eliminate stuck targets faster. Also worth running Spatial Intelligent Learning when the room’s empty to let the sensor map background noise.
The fact that you’re now trusting it for automations after all this tweaking says a lot—mmWave really does reward patience. Would love to hear how it stabilizes over the next few weeks, or if you find any other creative mounting solutions for that challenging space
