FP400 questions about M3 hub vs HA with Thread Antena
For the FP400, if you set it up first in the Aqara app and than set it up in home assistant, do you loose anything? or to get full features do you need an aqara hub? and does it perform similar with the aqara m3 hub vs a HA addon using a thread antenna?
@aqara_jvdubs Great questions about the FP400! Let me break this down for you.
On setup order and losing features:
The FP400 is a Thread-enabled device, and like other Aqara Thread devices, it can connect directly to Home Assistant via Matter over Thread if you have a Thread Border Router in your setup. However, here’s the key distinction: to access Aqara’s exclusive features—the rich custom settings, adjustable sensing ranges, delay durations, and advanced automation parameters—you’ll need to have it connected through an Aqara hub in Zigbee mode or use it within the Aqara Home ecosystem.
If you set it up in Aqara Home first, then bridge it to Home Assistant, you can leverage the Aqara Hub M3’s Advanced Bridge functionality. This lets you expose Aqara scenes and private functions to third-party Matter ecosystems like HA. So you don’t necessarily “lose” everything, but the native Aqara-exclusive tuning options live in the Aqara Home app.
On M3 hub vs. HA Thread antenna:
Performance-wise, both can serve as your Thread Border Router, but the M3 offers some unique advantages as a leading hub—it forms hub clusters, converts multi-hub automations from Cloud to Edge for better stability and speed, and has larger local storage with offline RTC adjustments. A HA addon with a Thread antenna will handle basic Thread routing fine, but won’t give you that Aqara-native optimization or the ability to coordinate other Aqara Zigbee hubs.
Bottom line: For full Aqara feature richness, keep the M3 in the loop. For pure Matter/Thread simplicity, HA alone works—but you’ll trade some of that deep configurability.
Hope this helps clarify the trade-offs! Any specific automations you’re planning with the FP400?
