Fritz_netmonitor Sensors Not Working Correctly
I’ve been trying to set up the fritzbox_netmonitor integration to keep track of my DSL status and throughput. I configured a few sensors using the template platform, but unfortunately, some of them aren’t working as expected. While most sensors like dsl_external_ip are showing the correct values, others like dsl_transmission_rate_up and dsl_transmission_rate_down are either showing zero or no value at all. This is quite puzzling because the attributes of the fritz_netmonitor entity seem to be correctly populated. I’ve double-checked my configuration, but I can’t seem to find the issue. Any ideas or suggestions would be greatly appreciated! Thanks in advance for your help. :blush:
