So I finally took the plunge and moved my Aqara G4 cam from HomeKit to Home Assistant… and honestly, I was expecting pain. But nope — turned out smoother than I thought.
For a bit of background, I’m more of a smart home enthusiast than an expert. I dabble. My HomeKit setup was fine, but I realized I wanted more flexibility — like linking cam triggers to automations that HomeKit just couldn’t handle the way I wanted. I had an old RPi 4 lying around, so I set it up with HAOS, and off I went.
Transferring the G4 was surprisingly easy once I figured out the right path. Tip: make sure you reset the camera properly and unlink it from HomeKit before you pair it in Aqara Home and then integrate with HA. I used the Aqara integration via Matter and also tried the RTSP stream for more control (frigate fans know what I mean
Now, I can trigger lights based on motion from the cam AND record clips in HA — something I couldn’t do reliably before. The latency is barely noticeable, and it actually feels more real-time than with HomeKit.
For anyone on the fence — especially if you’re trying to unify your smart devices across platforms — just do it. Happy to share more details if anyone’s curious or stuck mid-way. Ask away!
