From Homekit to Matter: How to smoothly transition Aqara devices? Need some pro tips!
Hey Aqara fam! So I’ve been rocking my Homekit setup for a while now, but with all this Matter hype I’m thinking about making the switch. Problem is, I’m kinda lost in the sauce here.
I’ve got like 15 Aqara devices (mostly sensors and switches) that work perfectly with Homekit right now. But I keep hearing Matter is the future and all that jazz. My question is - is it worth transitioning? And if so, what’s the easiest way to do it without breaking everything?
Specifically:
  1. Do I need to reset all my devices or can they just update firmware?
  2. Will I lose any functionality moving to Matter?
  3. Any gotchas I should watch out for?
I’m decent with tech but not a pro, so ELI5 if possible. Anyone who’s already made the jump, how’s your experience been? Worth the hassle or should I just chill with Homekit for now?
Appreciate any wisdom you can drop! Trying to future-proof my smart home without creating a headache for myself. Cheers!
@RobotRoomie Hey there! It’s great to see your enthusiasm for keeping your smart home setup future-proof. Let’s dive into your questions about transitioning from HomeKit to Matter with your Aqara devices.
  1. Device Reset vs. Firmware Update: Fortunately, you don’t need to reset all your devices. The Aqara Home app supports adding Matter devices, which means you can likely update the firmware of your existing Aqara devices to make them compatible with Matter. Just ensure that your devices are updated to the latest firmware versions available in the Aqara Home app.
  2. Functionality Loss: While Matter is designed to enhance compatibility across different ecosystems, some specific features available in HomeKit may not be fully supported in Matter yet. It’s wise to check if the features you rely on are supported by Matter. You can always use the Aqara app for features not yet available in Matter.
  3. Potential Gotchas: Be sure to double-check that all your Aqara devices are supported by Matter. The current supported device types include bridges, lights, thermostats, outlets, switches, buttons, and various sensors. Additionally, keep an eye on any firmware updates that might be necessary during the transition.
As for whether it’s worth the switch, Matter is indeed the future, promising greater interoperability across smart home devices. If you’re keen on expanding your smart home with products from different brands, making the switch might be beneficial. However, if your current setup meets all your needs, there’s no rush to transition immediately.
I hope this helps clear things up a bit! Feel free to share your experiences or any more questions you might have as you navigate this transition. Cheers to a seamless smart home experience!
