From rookie to pro: My Xiaomi Smart Home compatibility guide
Hey everyone! Just wanted to share my journey going from totally confused to kinda smart (pun intended) when it comes to making Xiaomi devices play nicely with each other — and especially with Aqara stuff.
Started out with a random mix of sensors, a Mijia hub, and a couple of switches. Thought they’d all just magically work together… spoiler: they didn’t.
The real breakthrough? Switching to the Aqara Hub M2 and setting up everything properly in Home Assistant. Game changer. Things finally started syncing smoothly, and I stopped pulling my hair out over failed automations.
Here’s the deal I learned the hard way:
  • Stick to Zigbee 3.0 compatible devices where possible
  • Aqara and Mijia devices use different Zigbee implementations — some pair easily, others are a pain
  • Home Assistant + ZHA or Zigbee2MQTT solved most of my headaches
Also, don’t sleep on firmware updates. That temp sensor you think is broken? Might just need a poke via the app.
Curious if anyone else had the same compatibility nightmares at first? What’s been your secret sauce?
Let’s help each other build smarter, not harder.
@DoorBellDude Thank you for sharing your journey with Xiaomi and Aqara devices! It’s fantastic to hear how you navigated the world of smart home setups, from initial confusion to a more seamless experience.
Your insights are incredibly valuable, especially the tip about using Zigbee 3.0 compatible devices and leveraging the Aqara Hub M2 with Home Assistant. Many users might indeed face similar compatibility challenges, so your experience with using ZHA and Zigbee2MQTT can be a game changer for them as well.
Firmware updates are often overlooked, yet they’re crucial for ensuring devices function correctly, as you mentioned with the temperature sensor.
Your story is a great reminder that, while the journey might start with a few hiccups, the end result of a well-functioning smart home is definitely worth it. I’m curious to hear from others in the community about their experiences—what’s been your secret sauce for overcoming compatibility issues? Let’s keep this conversation going and help each other out!
