After updating all five Aqara G100 cameras simultaneously, three went offline. One was recovered; two still fail with error 10036 despite repeated factory resets. Working cameras run firmware 4.5.45_0004. Both failing cameras were tested on Orbi RBE973S (including 2.4 GHz IoT) and independent Netgear MR6450 networks, using iPhone, iPad Pro and MacBook Pro. Same error persists. What can be the reason? what solution can be pursued further?
What region are you in? That error code appears to be a cloud connection or region mismatch error - the device won’t connect to Aqara’s cloud.
Does it still work locally? Can you stream it in other ecosystems or from local RTSP? Just to narrow down the scope of the issue.
In case anyone hasn’t seen this issue - have you opened a support case? If a release is breaking cameras, they should know and help out.
