G100 HomeKit Performance issues
Running version:4.5.45_0004 there are major live view performance issues on all of my G100 cameras via the home app. Image quality is extremely poor and laggy (more so when connecting outside of the network).
No issues when in Aqara app but I’ve found that if you remove the camera from the Aqara app and only run in Apple home performance is better so is this a firmware issue or just under powered hardware that can’t handle multiple eco systems?
Network conditions are excellent using high powered WiFi 6 router and cameras reporting perfect signal strength.
Anyone else seeing this?
Interesting? Do you only notice this on the G100 or do you have other Aqara cameras that are also effected.
I ask because earlier in the week I showed an update for my G5 Pro cameras. I updated those camera and now those same cameras can’t keep a Live Video feed alive. The cameras cut out and show a blank-black Live feed. They blink every few second and occasionally show the Live feed for a few moments but then go blank-black again.
It only effected my G5 Pro cameras. All my other Aqara cameras work just fine. I don’t have any G100’s at the moment.
When I try to use a different App to view the Live feeds the issues are not present and seem to work fine.
I wish I had not updated my G5 Pro cameras firmware a few day ago.
It’s just the g100’s I’ve got g5pro, g2hpro, g410 and they seem to be able to cope.
It’s odd that just running in Apple home only makes a difference which leads me to think it’s a hardware issue as the camera is a budget one. It’s also only one of the few cameras that the resolution is also capped in the Aqara app
Just to add I’m now getting the streams freeze after 5 seconds or so they the camera reporting as offline
Did you tried to change the resolution ? Is there something change?
You can’t change the resolution in HomeKit it’s based on network conditions / what the camera provides to the HomeKit hub
Hello @Heyhey88
If you use multiple systems, the resolution will automatically drop to 1080. This is stated by the manufacturer on the official website. Try turning off unused AI detection features, and the camera will work more stably.
This doesn’t work. All AI / cloud upload is off so the system isn’t doing anything in the Aqara app apart from being available for a live stream.
Also aware that that the resolution is capped but this isn’t the norm. Most Aqara cams allow for full native resolution in their app whilst being capped at 1080p in HomeKit (which is the Apple limitation). They say it’s due to encoding limitations of the hardware which backs up my point the camera is underpowered and can’t run in both ecosystems properly.
I bought four of these for around the outside of the house. I just set the first one up yesterday and I am experiencing the same issues. Picture quality through Apple Home was poor and there was lag…then I updated the firmware on the camera and now it freezes after around five seconds and the stream cannot rebuild. If I start a new stream, it’s fine for a few seconds. Stream seems completely stable in the Aqara app, albeit capped at 1080p resolution.
For what it’s worth, I think that the HomeKit issue may be the same as with the previous firmware, just worse. Prevoiusly, the steam quality would progressively degrade, starting after a few seconds; now it collapses and breaks the stream completely. Hopefully there can be a fix as it seems a brilliant product otherwise, given the cost.
Update: I have removed the camera from the Aqara app and the stream now appears to be completely stable in HomeKit. Obviously, this is a bit of a nuisance insofar as I can’t deal with settings in the app, etc. I would need to add it to the app again to change any of these and then remove it again. Hopefully, there is full fix, but as I now have it working in HomeKit I will likely just bash on with the other three to get the whole outside covered. I’m already using a G410, so had hoped everything would just work through the same system, but these are so cheap (i.e. four for much less than the cost of one G5), that the inconvenience is probably worth it.
I’m seeing this after about 20-40 seconds video jams yet there is still sound, then goes offline. This has only started since last firmware update as it was perfectly fine before [quote=“Heyhey88, post:1, topic:298810, full:true”]
[/quote]
Basically consistent with what I experienced after the firmware update. It might be as little as 6-7 seconds, but I might get up to 20 seconds of video. Then I would keep getting live sound with a frozen picture until the feed crashed completely.
I’ve been having the same issues with my camera since installed a new firmware. It’s making the cameras extremely frustrating.
Additional issue found today. I had to switch the camera off. when I switched it back on, the settings were messed up and the date and time stamp wasn’t showing on the feed. to reinstate this, I had to re-pair it with the Aqara app, which immediately remembered the camera and re-instated the previous settings. Unfortunately, the only way to do this meant removing and re-adding the camera to Apple Home. This has had the effect of detaching it from previous recordings in Apple Home. Please just fix the firmware, guys!
@Aqara_PM_Donie Can you shed any light on this one?
Installed a G100 today June 15/26. Have an Apple TV 4K 1st gen and was experiencing problems watching G100 video on my TV (via Apple aTV 4K). Btw, my G100 firmware was updated today. The video would stop after a few seconds and then the image would go black for a few seconds then would resume. I believe I found a solution and tested it several times. When I setup the camera (i.e. nothing in the Aqara app nor HomeKit) I would FIRST install the camera onto the Aqara app (using Aqara QR code). Then (sitting near the G100) I would use the Aqara app camera setting and select to add the HomeKit - this way you do never use the HomeKit QR Code. When I had problems I was further away from the camera and used HomeKit add accessory which then used the HomeKit QR code.
I never had to remove the camera from the Aqara app. Also I have installed a microsd card and recording continuously as well and stll my Apple TV camera image is running fine.
I do have a mesh router (Deco XE75 Pro) and went in there to change the Node the camera client was attached to as well.
I’m having the exact same problem it’s making this camera pretty much useless. It either says unresponsive. It never goes in the live mode and it usually lags stalls on watching past video feeds even it’s very frustrating. I wanna roll back to the previous version of firmware, but I don’t believe that the system allows that.
Here the same, since the last Firmware update, the G 100 doesnt work in Apple Home.
In my opinion, security devices in particular should function reliably.
I think, this was the last product i bought from Aqara.
Only real difference that I can ascertain between this and what I initially did is the presence of a Micro SD Card in the camera. I’m going to reset one of the cameras (I now have three G100s on the system) and test it with a Micro SD Card installed. I will see if that makes any difference…
I tried the steps set out with the Micro SD Card installed. It made no difference for me - the result was still a frozen image after a few seconds, with sound continuing. I tried changing to event recording, rather than continuous, but no difference there either. Only when I went back to the previous workaround of uninstalling the camera from the Aqara app did normal service resume in Apple Home. It worked fine as soon as I did that.
