I recently set up my new Camera Hub G350 and while live view works perfectly in Apple Home, HomeKit Secure Video is not recording any events.
Setup:
Camera Hub G350, Firmware: 4.5.20_0020.0017
Apple Home hub: Apple TV 4K + HomePod
iCloud+ subscription active
Recording Options set to “Stream & Allow Recording” for both When Home and When Away
Connected via 5GHz Wi-Fi 6 (WPA3)
What works:
Live view in Apple Home
Live view in Aqara Home app
Motion detection in Aqara Home app
Event recording in Aqara Home app
What does not work:
HKSV event recording - no clips appearing in Apple Home timeline
Recording works correctly within the Aqara Home app, which confirms the camera and motion detection pipeline are functioning as expected. The issue appears isolated to the HomeKit Secure Video recording handoff specifically.
Hi. I have a few questions to help get to the bottom of this:
Do you receive motion notifications from Apple Home for this camera, even though no clips appear in the timeline?
Under Accessory Settings → Recording Options → More Options, is “Any Motion” or “Specific Motion” selected, and in the case of the latter, which types (People, Animals, Vehicles, Packages) are checked?
In Home Settings → Cameras & Doorbells, does the G350 show any error or a “limit reached” message regarding your iCloud+ plan?
Which of your devices is currently shown as the active Home Hub? Have you tried a restart of that specific hub to force a new HKSV handshake?
Nope, no notifications other than when it’s switching modes. Otherwise all notifications are enabled. My other HKSV cameras are working properly except this new G350. I’ve removed and repaired the camera thinking it might’ve been that too, but still no HKSV other than Live.
I’ve rebooted my Home Hubs. Just can’t seem to figure this out, everything is working correctly in the native Aqara app and able to view the recordings there. I’ve left it like this for the last week but still won’t show any timeline.
Have you tried setting “When Home” to “Stream & Allow Recording” and “Any Motion is Detected” temporarily to see if the timeline and notifications appear immediately?
Does Apple Home correctly recognize your location? Make sure that you have My Location (Settings → Location Services) set to your primary iPhone and Share My Location turned on.
Regarding your iCloud+ plan: Which tier are you on (50GB, 200GB, or 2TB+), and how many HKSV cameras are you already using? Even though your other cameras work, you might have hit the limit for the 50GB (1 camera) or 200GB (5 cameras) plan.
By the way, check in the Home App under Home Settings → [Your Name] → Camera → Stream & View Recordings if it is set to “Stream & View Recordings”.
That’s great news! Apple Home can be a bit unpredictable sometimes.
It’s quite possible that after updating the recording rules, it just took a little while for iCloud to fully sync those new settings with your active Home Hub in the background.
Either way, I’m really glad to hear it’s finally working for you!
I have the exact opposite problem, event recognition and recording works fine but whenever I want to see the live stream in Apple Home, it just shows the latest frame from when I opened the feed and a spinning loading circle, after a while it gives an error message that the camera is not responding. However, in Aqara Home live stream works perfectly and reliably. Any takes?
Home Settings → Home Hubs & Bridges → Active Home Hub
Is it set to “Automatic Selection” or is a “Preferred Home Hub” selected?
Does the selected Apple Home Hub have good Wi-Fi reception? Or can you switch to another Apple Home Hub that is connected via LAN (Ethernet)? Have you tried restarting the Apple Home Hub?
Does the problem occur equally on all your devices (iPhone, Apple TV, Mac, iPad…)?
Does the problem only occur when you are connected to your Wi-Fi, or only when you are outside?
I only have one hub listed there (my TV) so there’s no selection. It occurred on all devices but I restarted the both the camera and the TV now and since then it’s working again.
