G350 ONVIF rollout: which capabilities need to be documented?
Aqara_PM_Donie said in the G350 thread that the evaluation is complete and firmware development is planned over the next few weeks. This is a plan; the feature has not been announced as released.
For someone connecting a G350 to an NVR, “ONVIF supported” still leaves practical questions: which profiles are available, how local discovery and authentication work, and whether audio and events are exposed alongside video. It would also help to know whether an existing RTSP setup needs any changes.
When the firmware is released, I would like to see a short capability list and tested integration steps. Which of these would you check first on your NVR, and what would you want Aqara to document?
Well if you run a Synology server and add it to Surveillance station it’s found by the server and depending on what you ask the server to register it will register movement, sound etc already now, the thing that is not supported though are PTZ features.
That distinction helps. Do you know whether Surveillance Station connects to the G350 through ONVIF, an RTSP URL, or a Synology camera profile? It would help separate the motion and sound events available today from what Aqara’s planned firmware might add, especially PTZ.
In the Synology server you can choose either ONVIF or RSTP when you add the camera.
Which option did you actually use for the working G350 connection in Surveillance Station: ONVIF or RTSP? If you tried both, did motion and sound events appear with both, and was PTZ unavailable in each? That would help distinguish what works today from the firmware Aqara has discussed.
Correction on my side. The G350 currently only support RSTP and NOT ONVIF. The G5 Pro support ONVIF and RSTP. I run the G5 Pro on ONVIF but the G350 RSTP and that might be the reason G350 doesn’t support PTZ as that would need ONVIF. Apologies on the mix-up.
