I am getting between 14 and 21 days of battery life using 3700mWh Li-Ion rechargeable batteries specifically chosen to support a video doorbell. I bought a set of 12, so I keep 6 in the charger and swap them every 2 to 3 weeks.
Is anyone aware of a higher-capacity battery that I could use in this doorbell? I have done everything I can think of to reduce power consumption, but it is fairly annoying to have to change so frequently. (Hardwiring is not an option).
@mrbaze That two-to-three-week cycle sounds frustrating, especially when you’ve already optimized what you can. A couple of things might be working against you here.
First, those 3700mWh Li-Ion rechargeables—are they 1.5V lithium-ion or 1.2V NiMH? The G4 specifically wants 1.5V discharge voltage; if you’re running 1.2V NiMH, the doorbell not only miscalculates remaining power but also tends to chew through them faster due to the lower voltage curve. Even with 1.5V Li-Ion rechargeables, there’s a known quirk: the battery level stays pegged above 90% until they’re nearly dead, so you might actually be hitting empty faster than it appears.
On capacity: the factory-equivalent baseline is about 2900mAh per cell, and the FAQ notes that capacity—not just mWh ratings—matters. Your 3700mWh cells, if 1.5V, translate to roughly 2467mAh, which is actually below that 2900mAh threshold. Look for true 2900mAh+ (or ~4350mWh at 1.5V) LR6 alkalines or high-quality 1.5V lithium primaries if you want longer stretches between swaps. Avoid mixing old/new or different chemistries in the same pack— that alone can nuke longevity.
Beyond batteries, the usual suspects: HomeKit integration keeps recordings running longer per trigger, short loitering intervals fire the PIR constantly, and weak repeater signal forces the radio to shout louder. If you haven’t already, test Power Saving Mode temporarily—it disables PIR entirely, waking only on button press or remote view, which stretches life dramatically at the cost of passive motion alerts.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
If you’ve already dialed in all of the above and still can’t break past a month, it may be worth a deeper look at whether your unit’s wake frequency or environmentals are outside typical bounds. Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
