Is there any fix for this? My 410 randomly started to freeze and lose connection a few weeks ago, now it’s almost every other day it loses connection, I have to fully reset the device to get it to re-establish.
The networking information shows it has more signal than the G4 on my Patio that works fine. I’m assuming my device is failing, but dealing with Aqara support on a warranty replacement is brutal.
@Smarthomesupernerd I’m sorry to hear about the persistent connection issues with your G410—constant disconnects and resets must be really frustrating! Let’s try some targeted troubleshooting steps based on common solutions for G410 connectivity problems:
First, even though the signal seems strong, double-check the distance between the doorbell and its repeater/chime. The recommended maximum distance is 5 meters to avoid signal instability . If they’re farther apart, try moving the chime closer temporarily to test.
Next, Wi-Fi interference could still be a factor even with good signal strength. Other devices on the same frequency might cause disruptions—try changing your router’s Wi-Fi channel to a less crowded one .
Power cycling might help too: Cut off power to the G410 doorbell, wait a minute, then restore power. Also, try placing the doorbell and chime side by side (e.g., on a table) while reconnecting, as this can sometimes resolve pairing hiccups .
If those steps don’t work, check the power supply. Ensure the voltage doesn’t drop significantly under load—corroded or faulty cables can cause intermittent connection issues, so inspecting/replacing the wiring is worth a try .
Finally, a factory reset (following the user manual) could clear any lingering software glitches .
Have you tried any of these steps already? Let us know how it goes—hopefully one of these gets your G410 back to stable operation
Yes I have, I contacted support and they immediately asked for access to my iPhone again.
There’s no way this company survives if their primary customer service point is “give me access to all of your information”.
I gave up and pulled the rest of my Aqara products to sell. I’d rather have Ring.
Same issue here. Disconnect every 1 to 4 days. Have to make the Chime powerless before it reconnect again. Doorbell is wired. Chime/hub is fixed to one AP and with fixed IP. Network connection is excellent. Using both the Aqara app and HomeKit. When a disconnect occurs, the doorbell still functions, the camera is offline until a power reboot from the Chime. Current firmware 4.5.20_0052.0108
I have the same issue. It is on battery, energy saving not enabled, on 2.4ghz to the router, hub is behind the wooden frontdoor, the doorbell outside near the frontdoor. The router is near the hub. I have set it to fixed ip and set security to wpa2-psk but it still disconnects randomly after a few hours or less. I bought it a few weeks ago. It is on batteries. Could that be the issue?
