G410 dead cat options
Dont worry, this is not about animals :rofl:
The street I live on is a bit of a wind tunnel, are there any options people have for dead cats to help with the microphones on the G410?
I don’t think there are dead cats for smart doorbells (probably they are difficult to apply), but I’ve heard that protective covers/guards help a bit. The deeper the cover, the better.
Thanks, I thought as much tbh.
Ill see what I can design and 3D print over the weekend.
Isn’t there simple foam windscreen material available for this? You could probably grab a larger sheet at a hardware store or on Amazon, cut it to size, and carefully attach it to the side using adhesive tape.
I assume the opening on the side houses both the microphone and the speaker, though I’m not 100% sure. That said, foam would definitely get soaked in the rain, and it might also muffle the speaker output.
Also, if you go the 3D-printed cover route: make sure the design doesn’t reflect the infrared LEDs back into the camera lens at night. Otherwise, the IR glare will completely blind the night vision.
Night vision is not an issue for me, we have a street light across the road that pretty much disables the night vision entirely. I’ve never seen it active.
I thought the mic was the little pin hole at the top of the lens?
Yes, I think you’re right. When I tapped on the housing, the noise was loudest near that little hole. It’ll probably be tricky to attach anything there.
As I said before, the best solution will probably come from a 3D printer or a wind tunnel. :rofl:
