G410 doorbell install and mechanical chime
I haven’t been able to find anything mentioned in G410 doorbell install instructions that tell what to do about the existing mechanical chime. Do I remove it or keep it int he doorbell wiring loop?
If you have a regular old bell - then of course remove it, because the G410 will completely replace it for you.
The G410 doorbell currently does not support making your old doorbell work with the new one at the same time. Raman is right. If you use the power supply of the old doorbell to power the G410, the old doorbell will not work.
Super duper, just the info I needed. Thank you! Will unwire the old doorbell from the circuit. Thank you for your help!
Thank you Raman! That was the info I needed.
