I have the G410 doorbell since last year (also a H2 wall outlet and a T2 bulb). Problem is my front door is very far from where I connect the hub. Is there some way to connect the G410 by cable? or what do you do in this case, repeater or something? thanks
I am curious to know this too, since I have the G410 set up with batteries but would prefer it to be wired.
You can hardwire the G410 for power, but it has no LAN port. The Chime Hub and the doorbell talk over their own WiFi network, so keep them close together. You can then easily extend the WiFi to the Chime Hub with a repeater or a wired access point.
thanks, didn’t know they use their own wifi between them. So I put the chime hub near the door and the repeater is only for the chime, right?
That is exactly right. And if the Chime Hub can no longer be heard, you can also have an Aqara Hub or a HomePod ring. Or you can even control smart lights to make them flash.
I have my G410 wired using an old router power supply with the matching voltage, and the Chime/Hub is about 5 meters away—everything works great. Even with my Hub M3 quite far away, it integrates seamlessly with all my devices, and I even linked the doorbell to my Aqara smart lock
