Having issues with my doorbell. When the button is pressed, the chime isn’t heard from the receiver, the chime only sounds at the doorbell. Ive looked at all the setting, im not sure what the problem is. G410 is connected to M3 hub. Ive tried both battery and shore / doorbell power, same result any and all help appreciated.
Hello @vic81986
Welcome to the Aqara forum
You may have muted the speaker module. Check the settings again and see if it works through automation (you need to create one). You may have do not disturb mode enabled. If that doesn’t work, I would reset the ringer to factory settings and check after re-adding it to the app.
