I check my external power and I have 24 v ac at the door bell and also put brand new battery and the g410 didn’t turn on
Hi there.did you check if works without batteries?also taking the cables out and try with only batteries?you need to troubleshoot each possibility in order to go further.also you can contact Aqara support in the mean time and explain the issue to them too.
I changed the battery, check the wire power I having 24v ac still not getting power on
What I was trying to tell you is to try :
First take out the batteries and let it connected to the power see if that will give you something as if does then your batteries could be the issue.
Second: if the first try do not work then take off the power cables and add only the batteries see if this way could work as my be could be your transformer the issue.
3th if all fails then please contact Aqara support for more in depth evaluation.
Thank you for trying to help me, but I reach out to aqara today and there are working with me
