Since last week, I have a massive breakdown in G410 functionality.
On Wednesday, my router needed a power flip. Since that moment:
- The the live video feed would not load in the Aqara & Apple home app. At this point in time the chime worked, as well as notifications in the Aqara and Apple Home apps
- Since yesterday, nothing happens anymore when pressing the doorbell: no notifications or chime (both the chimebox and the house’ built-in chime
My doorbell is:
- hardwired
- connected with Apple Homekit
- connected with Homeassitant via matter
- firmware: 4.5.20_0052.0090 → I see an update to 4.5.20_0052.0108. Installing says succesful, but then restarting the app, the firmware is still the old one.
- My chimebox is 1 meter (3 feet) from the doorbell
Anybody ever ran into this?
Did you ever get this resolved? I had a very similar G410 case in October, including exactly the same 4.5.20_0052.0090 → 4.5.20_0052.0108 update loop and unreliable live view in both Aqara Home and Apple Home.
Aqara support clarified in my case that the indoor chime had updated while the outdoor doorbell was still on older firmware. Their suggested recovery was to reset the outdoor doorbell using its rear reset button for 15 seconds, power it with batteries, place it close to the chime, and retry the update. A reset means setting it up again, so I would first check and record the separate firmware versions shown for both components. These were support recommendations for my case, not a guaranteed fix for yours.
My later firmware screen showed 4.5.80_0002.0108 and doorbell firmware 4.5.5. Live view had already returned before that confirmed update, so I cannot say the firmware update alone fixed it. I documented the sequence here: G410 update reports success but repeats: chime and doorbell firmware mismatch
I have installed seven G410 units for friends and family, but I would not assume this particular failure affects all of them. If yours is still affected, which versions do the chime and outdoor doorbell show now, and does the physical chime still ring?
Correction to my previous reply: after checking the model names, the doorbells I installed for friends and family are a mixture of G4 and G410, not seven confirmed G410 units. My own home doorbell is a G4. I am also rechecking which device the earlier troubleshooting records refer to, so please do not treat my personal recovery sequence or firmware versions as a verified G410 fix. The support advice was given for a case described to Aqara as a G410; that description alone does not resolve the model uncertainty. Please confirm your own model and firmware with Aqara before applying model-specific reset instructions. Sorry for the confusion.
