Just wondering has anyone else experienced G410 Doorbell hub instability after adding FP400’s in zigbee mode to the hub? I added two and I’ve had trouble ever since. I’ve opened a ticket to Aqara and they are suggesting a beta firmware update. First my hub crashed entirely and I need to restart it by removing the power cable. After this I’m experiencing daily “crashes” or loss of device connectivity. The Hub goes into offline status twice a day. Am I the only one?
Thanks, I already opened a ticket before this post and I’m waiting for a beta firmware release. Another symptom today was that the connected Zigbee child devices didn’t respond to any commands. The hub itself reported itself being online but was totally “hung”, it didn’t accept any camera connections and the RTSP-feed’s also were down. Had to restart it.
Hopefully the new firmware will fix this, or then I have to contemplate on changing from zigbee to thread.
@juha_teno That sounds incredibly frustrating, and you’re definitely not alone in experiencing hub instability with complex Zigbee setups. The symptoms you describe—Zigbee child devices going unresponsive while the hub reports “online,” camera connections failing, and RTSP feeds dropping—point to the G410’s Zigbee coordinator getting overwhelmed or stuck rather than a true network disconnect.
A few things worth considering while you wait for that beta firmware:
On the Zigbee side: Heavy Zigbee traffic from multiple FP400s (especially if they’re routing traffic for other devices) can push the G410’s processor hard. The “hung but online” state you described is a classic sign of the Zigbee stack freezing while the Wi-Fi/ethernet side stays alive. If you haven’t already, try powering down all Zigbee devices, then bring the FP400s back online one at a time with a day or two between each to see if load correlates with crashes.
On switching to Thread: It’s a valid thought, though be aware the G410’s Thread implementation is still maturing. Thread topology is self-healing and generally more resilient, but you’ll need to ensure your border router setup is solid and that all your end devices support Thread natively or via Matter bridging. The reference info notes that Matter/Thread pairing requires specific hub firmware and IPv6 support, plus careful Thread network management if you’re running multiple controllers[“content_id”:5"].
Immediate relief: Since you’re already in Aqara’s support pipeline and they’ve flagged a firmware fix, the beta is likely your best near-term bet. In the meantime, reducing Zigbee mesh complexity—temporarily removing one FP400, or repositioning them to minimize routing hops—might buy you stability.
Has support given any timeline on the beta, or indicated whether the fix targets Zigbee coordinator memory leaks specifically?
I received new 4.50_80-0002.0114 firmware and now there a no crashes anymore
@juha_teno Hi @juha_teno,
That is fantastic news!
It’s always a relief when a firmware update resolves those tricky instability issues, especially with complex Zigbee setups like the G410 and FP400s.
Thank you for sharing this update with the community. It’s incredibly helpful for other users facing similar “hung” hub states or connectivity drops to know that version 4.50_80-0002.0114 is the fix. If anyone else is experiencing G410 crashes after adding motion sensors, they’ll definitely want to check their firmware version first.
Keep enjoying your stable smart home setup! If you have any other insights or tips on optimizing your Zigbee mesh, feel free to share them with us.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
