G5 Pro PoE – Face recognition automation not triggered when alarm is armed
Hi,
I’m using Aqara G5 Pro PoE cameras. I have both Armed and Disarmed modes configured, and known faces are correctly registered in the Aqara Home app.
I created an automation to automatically disarm the alarm when my face is recognized.
The problem is that as soon as the alarm system is armed, the face-recognition automation does not trigger at all. I added a simple push notification to the automation for testing, and even that notification is never triggered.
However, when the alarm is not armed, an automation such as:
My face recognized → Send notification
works perfectly every time.
Has anyone experienced this with the G5 Pro PoE? Is face-recognition automation intentionally disabled while the alarm system is armed, or is this a bug?
Hi. First of all, a warm welcome to the forum!
I forwarded the facial recognition to Home Assistant via a Matter signal. According to the logs, I can see that the facial recognition triggers an automation in Home Assistant, but it is stopped by a condition because the alarm system is armed.
Basically, the facial recognition of my G5 Pro (PoE) and G410 seems to work even when the alarm is armed. However, I actually also enabled notifications for when a face is detected, and that just didn’t work while the alarm was armed.
What exactly isn’t working for you? Is it the device notification or an automation with a notification in the Aqara Home app? Or is it a Matter signal, as in my case? Which alarm mode (Home, Away, or Night) did you have enabled?
Edit: Correction, I did receive the notifications from the G410 and G5 Pro after all. The messages are there under Profile → Message Center. The notifications probably weren’t displayed on the iPhone because I had the Aqara Home app actively open at the time. By default, iOS suppresses standard push notification banners if the app sending them is currently open and active in the foreground. So, if you just armed the alarm and didn’t close the app or send it to the background, you won’t see the notifications.
Thanks for your detailed reply!
I’m not using Apple Home or Home Assistant at all — I’m only using the Aqara Home app.
Here is exactly what I’m trying to do:
I arm the alarm in Away mode, and I have created an automation in Aqara Home:
IF: my face (Christophe) is recognized by the G5 Pro
THEN: send me a notification AND disarm the alarm.
The problem is that when I test it, as soon as I walk in front of the camera while Away mode is armed, I immediately get the “Lurker detected” message saying that the alarm will be triggered in 40 seconds.
After that, my facial-recognition automation does not seem to execute at all, so the alarm is not disarmed.
I then did another test to make sure facial recognition itself was working. I removed the disarm action and tested a very simple automation:
IF: my face is recognized
THEN: send me a notification.
In that case, it works perfectly: the camera recognizes me as Christophe and I receive the notification.
So facial recognition itself definitely works. The issue seems to be specifically when Away mode is armed. It looks as though the alarm’s entry countdown takes priority, and once the “Lurker detected / alarm will trigger in 40 seconds” sequence has started, my facial-recognition automation is no longer executed.
What I’m trying to achieve is quite simple: when I arrive home, the G5 Pro recognizes my face during the entry delay and automatically disarms the Aqara alarm before the 40-second countdown expires.
Have you ever tried this specific setup entirely within the Aqara Home app?
