I am having an issue with my Aqara G5 Pro POE not binding to HomeKit. I’ve tried everything from resetting my G5 pro, Restarting my network, changing multiple setting in my Eero 7 Max, adding G5 Pro directly to HomeKit, nothing seems to work. The camera was connected for about a month or so but would randomly unbind from HomeKit but this time I am unable to get the camera to connect to HomeKit. Everytime I tried to bind the camera to HomeKit via the Aqara app or directly to HomeKit bypassing Aqara app the camera shows up as “No Response”. I have a second G5 Pro POE that is working fine. Idk what to do. Both cameras are on an unmanaged POE switch wired directly to my main Eero 7 Max coming from my ONT box. My Apple hub is my AppleTV box located in my master bedroom that is connected via LAN. I’ve been having issues with my Aqara cams getting “No Response” in HomeKit very since they have been installed but I’ve been able to get them to have a stable connection except one. That camera seems to have an issue. I am able to view it through the Aqara app just not the Apple home app. Has anyone ever had this issue?
Hello, welcome to the forum.
Try the following steps. 1. Remove from HomeKit. 2. Remove from Aqara Home. 3. Reset to factory settings (10 quick clicks). 4. Turn off the camera. 5. Restart the router. 6. Add G5 to Aqara Home. 7. Add to HomeKit from aqara settings.
Thank you for the suggestion but that didn’t work either. I’m thinking the issue with HomeKit and not the cameras themselves. When I tried your suggestion three more of my cameras went “No Response” and I can not add them back to HomeKit as well. I’m figuring of quitting HomeKit all together. Nothing is really stable with HomeKit lately.
Hello, welcome to the forum. Even if you have a problem with HomeKit, please contact Aqara support. They will check the problem and make a decision to fix it.
Try removing the Eero 7 Max from the equation for one last test.
Connect the ONT Box directly to the unmanaged POE switch and see how the G5 Pro’s respond. Everything would be hardwired with no middle man.
