G5 Pro POE won't respond after firmware update
I have had my G5 Pro POE for over a year. It has been working great. Yesterday I was in the Aqara Home app on my iPhone and I saw there was a firmware update available. I initiated the firmware update. It began downloading the update 10%, 20%, etc. and I just walked away… about 30 minutes later I went back and the camera had a yellowish/greenish light on the front and it showed not connected in the Aqara Home app… I tried unplugging the ethernet/POE connection, restarting the camera, POE switch… nothing changed. I tried pressing the reset button for 10 seconds, 10 quick presses, holding it for 50 seconds looking for purple flashes, tried connecting it to power via the USB C cable and to a non-POE switch… nothing… It just shows the yellowish/greenish steady light on the front. I have removed it from the Aqara Home app AND my Apple Home setup. I just want to do a factory reset and start all over… just can’t get it to do anything. This camera has never been outdoors. Nothing has changed with my network setup. I tried various cables, etc. Ideas? TYSM
Hello, this has happend to me and it sound like a bad flash that has bricked the device, please reach out to support as they may replace this under warrenty as this happend during an update.
In the future hen dealing with devices like cameras and hubs I tend to do a reboot 1st just to make sure a full reboot occurs and recovers from a reboot ok, this also clears the memory, I then proceed with a firmware update.
You may be able to recover the camera with the help of support but I suspect it’s dead. As the G5 Pro does not contain an SD card there is probably no way to recover.
Reach out to support
Thank you! I have reached out to technical support. I’ll post back here on how things turned out.
I’ve been working with support. They think it is dead too and will likely be replacing it. They asked to have access to the device logs and to confirm my address and phone number. I’m hoping it gets replaced soon!
I received my replacement POE G5 Pro today in the mail. I will be setting it up tonight. I assume I set it up in the Aqara Home app and then later add it to Apple Home… (not HomeKit, but Home).
In the future when I see there is an update, I will unplug the camera, wait a few minutes, plug it back in, be sure it reboots and shows up in Bothe the Aqara Home app and Apple Home and then I will return to the Aqara Home app to proceed with the firmware update.
Does all of this sound correct?
Yrs, i cant comment on apple home as i do not own any apple equipment
