Hi everyone! I bought a G5 Pro Wi-Fi (CH-C07E) for my garden in Germany, but it is not installed there yet. I was considering an external USB power bank and am now also looking at a dedicated battery/solar camera such as the G510.
Has anyone measured G5 Pro runtime from a power bank? Which capacity in Wh and recording settings did you use? Did automatic shutoff or restarting after a depleted bank cause problems?
I have not tested this setup yet. Actual measurements would help me decide whether the power-bank approach is practical. Thanks!
@justin17 Hey there! Great question — a power-bank-powered garden cam is a really practical idea, especially when wiring isn’t an option.
From the specs we have, the G5 Pro Wi-Fi draws 5V/2A via USB-C (so roughly 10W under load). That gives you a rough baseline: a 50Wh power bank would theoretically last around 4–5 hours of continuous operation, while a 100Wh unit might stretch to 8–10 hours — but real-world runtime depends heavily on your recording settings (resolution, frame rate, night vision spotlight usage, Wi-Fi signal strength), plus power bank efficiency and voltage conversion losses.
A few things to keep in mind for your setup:
Cold weather in Germany will reduce lithium battery capacity significantly — expect 20–40% loss in winter.
Startup behavior after full depletion: Most power banks cut output when voltage drops, so the G5 Pro would shut down hard. Whether it auto-recovers when you swap or recharge the bank depends on the power bank’s re-trigger behavior and whether the cam needs a manual button press to boot.
Solar pairing: If you’re already eyeing the G510, a small solar panel + power bank combo (with pass-through charging) might bridge the gap for the G5 Pro Wi-Fi, though it’s not officially supported.
Unfortunately, I don’t have measured runtime data from the field in our reference materials — this would be perfect community knowledge to crowdsource! If anyone’s actually tested Wh-per-hour consumption with specific settings, please chime in.
If you end up running your own tests, I’d love to hear the numbers. And if the power-bank route gets too finicky, the G510’s native battery/solar design is purpose-built for this exact use case.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Thanks for distinguishing estimates from field measurements. One important clarification for anyone comparing power banks: a 5 V / 2 A supply rating alone does not establish that the camera continuously consumes 10 W. Runtime needs the measured average consumption and usable energy at the USB output, including conversion losses.
I am still looking for actual G5 Pro measurements rather than a runtime calculated from the supply rating. If anyone has tested it, please include power-bank capacity in Wh, recording/spotlight settings, ambient temperature, and whether the camera restarts automatically when USB power returns. I have not tested this setup myself yet.
Das ist der aktuelle, momentane Stromverbrauch meiner G5 Pro WiFi (mit aktiviertem Spotlight). Dann kannst Du selbst nachrechnen, wie lange eine Powerbank (je nach Kapazität) durchhalten würde.
Danke für die konkreten Messwerte! Die angezeigten 3,0 W mit aktiviertem Spotlight sind für die Einschätzung viel hilfreicher als allein die Netzteilangabe. Misst du an der Steckdose inklusive Netzteil oder direkt am USB-Ausgang? Und läuft dabei eine Daueraufnahme?
Für eine Powerbank wäre zusätzlich der Durchschnitt über Tag und Nacht interessant. Als reine Rechenhilfe: 50 Wh tatsächlich nutzbare Energie am USB-Ausgang würden bei konstant 3 W etwa 16,7 Stunden ergeben. Das ist keine gemessene Laufzeit und berücksichtigt noch keine abweichende Last oder Kälte. Ich habe meine G5 Pro noch nicht an einer Powerbank getestet.
Ich messe den tatsächlich aus der Steckdose gezogenen Stromverbrauch, ohne ein USB-Netzteil. In der Steckdose ist ein USB-Stecker verbaut, den ich zur Stromversorgung nutze. Daher brauche ich kein weiteres, externes Netzteil. Tagsüber ist bei mir das Spotlight deaktiviert, mit Sonnenuntergang aktiviert sich das automatisch auf 10% Helligkeit. Bei Erkennung eines Ereignisses schaltet es 4 min auf 100%, danach auf 10% bis zum Sonnenaufgang zurück.
Willst Du den gemittelten Stromverbrauch ĂĽber einen Tag, eine Woche oder einen Monat wissen?
Na ich lese das mal aus und hänge es nachher noch hier dran…
P.S. Ich habe die Kamera im 2k-Modus (also höchste Auflösung) dauerhaft auf Streamen&Aufnahme im HomeKit, Google Home und Samsung SmartThings laufen, in der Aqara-App werden Ereignisse aufgenommen, zwischengespeichert und zusätzlich alle 1h auf ein NAS hochgeladen.
P.P.S.
Hier noch die versprochenen Screenshots zum Energieverbrauch der G5 Pro Wifi:
Danke, damit sind die Messbedingungen viel klarer: Messung an der Steckdose, tagsüber ohne Spotlight, nachts 10 % und bei Ereignissen kurzzeitig 100 %. Auch die zusätzlichen Streams und NAS-Uploads sind hilfreicher Kontext.
FĂĽr den Vergleich mit einer Powerbank wĂĽrde ich den Wert deshalb als Leistungsaufnahme deines gesamten Versorgungswegs einordnen: Auch bei einer Steckdose mit eingebautem USB-Ausgang findet die Spannungswandlung in der Steckdose statt. Der Messwert ist also nicht automatisch identisch mit der Leistung direkt am USB-Kabel.
Am aussagekräftigsten wäre noch der Energieverbrauch über volle 24 Stunden in Wh oder kWh; daraus könnte man einen Tagesdurchschnitt ableiten, der die wechselnde Spotlight-Last mit abdeckt. Meine 16,7 Stunden oben bleiben nur ein Rechenbeispiel mit konstant 3 W und 50 Wh tatsächlich nutzbarer USB-Energie, keine zugesicherte Laufzeit.
Ja, Du müsstest halt direkt am USB-C-Stecker messen, kannst das aber auch näherungsweise errechnen. Der angegebene Messwert ist ohne den Eigenbedarf der Steckdose, den der Hersteller mit <0,2W angibt. Damit sind die 3 Watt das, was in dem Moment tatsächlich von der Kamera gezogen wird. Das Spotlight wirkt sich kaum aus; im Bereich von 0,1 Watt. Mehr schwankt es nach oben, wenn gerade der stündliche Upload stattfindet oder aktiv ein Ereignis aufgezeichnet wird. Dafür ist es im „Ruhezustand“ etwas weniger. Am
aussagekräftigsten sind da tatsächlich Mittelwerte über eine Stunde oder eben 24 Stunden (wie oben). Bei einer Outdoor-Kamera kommen natürlich noch Schwankungen je nach Außentemperatur, Sonneneinstrahlung, Luftfeuchtigkeit, genutzte WLAN-Verbindung (Netz, Band, Kanal (insb. im 5 GHz-WLAN unterscheidet sich die Sendeleistung), genutzte Kameraauflösung usw. usf. hinzu. Da sind wir aber schon im Zehntelwatt-Bereichen.
Man kann es also auch ĂĽbertreiben.
Für Deinen Anwendungsfall mit einer Powerbank-(Not-)Stromversorgung rechne doch für die benötigte Kapazität einfach mit Näherungswerten, gib 25% Sicherheitsreserve dazu und Du bist auf der sicheren Seite. Lieber etwas zu viel als zu wenig; dann schläfst Du ruhiger.
Danke dir für die ausführliche Erklärung und die nachgereichten Verbrauchsdiagramme! Die hatte ich bei meiner letzten Antwort übersehen. Damit habe ich jetzt eine brauchbare Größenordnung für die Planung, statt nur mit der Netzteilangabe zu rechnen.
Du hast recht: Für die erste Einschätzung muss ich daraus keine Wissenschaft machen. Die Größenordnung um 3 W aus deinem Aufbau ist hilfreich; wie lange meine konkrete Powerbank tatsächlich durchhält und ob die Kamera nach einer Unterbrechung wieder startet, müsste ich dann praktisch testen. Danke für die Mühe mit den Messungen!
