Hey everyone, I wanted to share my recent experience with the generic camera integration in Home Assistant. It was quite the puzzle, but I managed to figure it out, and I hope this helps someone else avoid the same frustration.So, the problem started when my three generic cameras stopped working after exactly 24 hours. At first, I thought it might be a one-off glitch, but it happened consistently every day. The cameras would work perfectly fine, and then boom—they’d go dark. I checked the logs, and there were errors about connection attempts failing and timeouts. It was pretty frustrating, especially since the live feeds were still accessible through my phone app and the browser.I started by looking into the configuration. I have two Amcrest cameras and one Foscam, all set up using the generic camera platform. The Amcrest integration doesn’t support HTTPS, which I found a bit limiting, but the Foscam was giving me even more trouble due to its security vulnerabilities. I decided to stick with the generic setup for both security and functionality reasons.One of the first things I noticed was that rebooting the server would temporarily fix the issue. But obviously, rebooting every 24 hours isn’t a sustainable solution. I needed to get to the root of the problem. I checked the camera URLs and authentication settings repeatedly, but everything seemed correct. The issue wasn’t with the initial connection but with maintaining it over time.After some research, I came across mentions of SSL certificate issues and connection timeouts. I decided to test the cameras individually to see if the problem was camera-specific or a broader system issue. Interestingly, all three cameras exhibited the same behavior, which pointed more towards a configuration or system-wide issue rather than individual camera problems.I then looked into the Home Assistant logs more closely. The errors indicated that the system was having trouble re-establishing connections after an initial period. This made me think about the keep-alive settings and connection timeouts within the generic camera integration. I started experimenting with adjusting these settings, but unfortunately, there wasn’t much documentation on how to tweak them specifically.In the end, I found that upgrading to the latest version of Home Assistant (Core-2022.2.6) resolved the issue. It seems like the problem was related to a bug in the previous versions that has since been patched. After the upgrade, the cameras have been working without any interruptions for several days now.This experience taught me the importance of keeping my software up to date and thoroughly checking release notes for bug fixes. It also highlighted how a community-driven platform like Home Assistant can continuously improve with regular updates.If anyone else is experiencing similar issues, I’d recommend starting with a fresh configuration, checking the logs for specific error messages, and ensuring that all your integrations are up to date. Sometimes, the solution is just a minor update away!Thanks for reading, and feel free to share your own troubleshooting stories or tips below. Happy automating! ![]()
