Getting Started with Aqara Agent Skills on OpenClaw
I. What are Aqara Agent Skills?
Aqara Agent Skills is Aqara’s official skill collection for agent-based ecosystems.
It is designed to bring Aqara capabilities into modern AI agent workflows through a growing set of reusable skills. As the collection expands, Aqara Agent Skills will continue to support more scenarios, more integrations, and more ways for users to interact with Aqara smart homes through natural language.
At this stage, the featured skill is Aqara Agent.
II. What is Aqara Agent?
Aqara Agent is the current skill in the Aqara Agent Skills collection.
It enables OpenClaw to understand Aqara homes, rooms, and devices, and to perform supported device queries and control actions through natural language. With Aqara Agent, users can connect their Aqara account, access home and room information, check device status, and send supported commands to compatible devices through a more natural and conversational experience.
III. What can Aqara Agent do?
Aqara Agent currently focuses on four core areas: account and home setup, space inquiry, device inquiry and status reading, and supported device control.
Overview of current capabilities
Function Description Example
Account & Home Setup Guide users through account connection, retrieve the list of homes, and select or switch the current home “Connect my Aqara account”
Space Inquiry Show the rooms and spaces in the current home “What rooms are in my home?”
Device Control Send supported control commands to compatible devices “Turn off the living room AC”
Device Inquiry List devices, locate devices by room, and read device information “What devices are in the bedroom?”
Device Status Check current device state and supported attributes “Is the bedroom light on?”
Aqara Agent supports a range of common smart home interactions, including account connection, home selection and switching, room and device lookup, device status inquiry, and supported device control.
Supported control types may include actions such as on and off, brightness, color temperature, color control, curtain percentage, temperature setting, wind speed, wind direction, and volume or playback-related controls for supported devices.
IV. What is not supported at the moment?
At this stage, Aqara Agent does not support certain categories of interaction, including:
  • Camera live view or playback
  • Smart lock lock or unlock actions
  • Scenes
  • Automations
  • Energy-related queries
  • Weather-related queries
For these scenarios, users should continue using the Aqara Home App.
This helps keep the current Aqara Agent experience focused, reliable, and well-aligned with supported capability boundaries.
V. How to add Aqara Agent to OpenClaw
Getting started with Aqara Agent only takes five steps:
  1. Install Aqara Agent
    Copy the GitHub link of Aqara Agent Skills into the OpenClaw chat and ask OpenClaw to install the skill.
    GitHub: [https://github.com/aqara/aqara-agent-skills]
  2. Get the Aqara login link
    After installation, Aqara Agent will guide you to the Aqara account login flow and provide the required login link[https://agent.aqara.com/login]
  3. Select your account region and sign in
    Choose the region where your Aqara account is registered, then sign in with your Aqara account.
    After login is completed successfully, you will receive a login token.
  4. Provide your token
    Copy the login token and provide it to Aqara Agent so it can connect to your account.
  5. Select your home and start using it
    After the token is verified, Aqara Agent will retrieve the homes available under your account. Once you select the home you want to use, you can start chatting with Aqara Agent right away.
At that point, you can begin with prompts such as:
  • “What rooms are in my current home?”
  • “What devices are in the bedroom?”
  • “Is the bedroom light on?”
  • “Turn off the living room AC”
VI. Environment requirements
To use Aqara Agent, make sure the following requirements are met:
  • OpenClaw is available and ready to install skills
  • The environment can access the Aqara account login page and related service endpoints
  • The Aqara account is active and can complete the login flow normally
After installation, it is recommended to start using Aqara Agent in a fresh OpenClaw conversation so the setup flow can proceed smoothly.
VII. First-time setup experience
During the first-time setup flow, Aqara Agent will guide the user through account connection, token submission, and home selection. Once setup is complete, the user can start interacting with Aqara devices through natural language.
Example prompts:
  • “Set the bedroom AC to 26 degrees”
VIII. Reliability and privacy
Aqara Agent is designed to work with real Aqara platform data and real device capabilities.
That means it should only present information that has actually been retrieved, and it should only confirm actions that have actually been executed successfully. This helps ensure a more trustworthy and practical experience for smart home scenarios.
Account credentials and access tokens should be handled securely. They should not be exposed in public conversations, screenshots, or source control.
IX. Learn more
To explore Aqara Agent Skills and get started with Aqara Agent, visit the official repository:
GitHub: GitHub - aqara/aqara-agent-skills: Aqara's official AI skills library · GitHub
We hope this helps you get started with Aqara Agent Skills on OpenClaw.
Feel free to try it out and share your feedback with the community.
If you have any Aqara Skills you would like to experience on OpenCalw, please share your thoughts with us in the comment section.
I’ll definitely give it a try on the weekend!
Agent is downloaded already but is waiting for its setup
ClawHub:Aqara Agent — ClawHub
Oh, an MIT licence on it. That’s interesting.
This is interesting !
Is it available now? If you encounter any issues while using it, feel free to leave a message here.
Yes, it’s working! Can turn on/off the lights, adjust thermostats and turn on/off the power plugs/sockets I have. All in all it works pretty good for me so far
Oh, what I’d love to see is an option to create or edit automations in Aqara Home or asking for firmware updates or install the updates via openclaw. Is there a way to integrate these features in the future?
Great!
Thanks for your feedback! We’ll support the features you mentioned soon.
That’s awesome! Thanks for including the features. Looking forward!
A update on Aqara Agent Skills for OpenClaw:
At this stage, Aqara Agent supports more smart home workflows than before.
In addition to the capabilities already introduced earlier, Aqara Agent now also supports:
  • Device activity and recent event logs For example: “How many lights are at home?” Or: “Is anyone at home?”
  • Scene query, scene execution, and scene execution history For example: “What scenes do I have?” Or: “Run the Movie scene.”
  • Automation query, automation detail lookup, automation enable/disable, and automation execution history For example: “What automations do I have in the bedroom?” Or: “Turn off the Away automation.”
  • Energy consumption and electricity-cost statistics for a specific device type, by room, or for the entire home For example: “How much electricity did my air conditioners use this week?” Or: “How much electricity did the living room use last month?”
Scene creation and automation creation are also under development and will be supported in future updates.
If you would like to get the latest version of Aqara Agent on OpenClaw, you can simply say: “Update Aqara Agent
Skill.”
We hope this update helps make Aqara Agent even more useful for everyday smart home use on OpenClaw.
cool!!
Currently running Aqara Agent Skills on Gemini models via API. It’s been a fun experience, especially watching the agent learn to control new devices by analyzing my manual operation logs.
@Timothy_Chen_Aqara, please add support for the preinstalled lighting effects on the T1M and T2 bulbs (e.g., Sleep, Read, Colorful, Sunset, Holiday, Autumn…)
Thought on a broader note, while cloud-based models (even the lighter ones) still probably keep outpacing big, slow, precise local models like Qwen3.5 122B+… in some terms, as privacy matters, it makes me wonder what the “sweet spot” for a local model size would be for a typical smart home.
P.S. Costs aside, are many of us secretly waiting for a Mac Studio M5 Ultra with 1000+ GB/s bandwidth? :eyes:
Here is another update on Aqara Agent Skills for OpenClaw:
In addition to the device logs, scene query and execution, automation query and toggle, and energy statistics mentioned earlier, Aqara Agent now also supports more scene-related capabilities.
The newly supported features include:
  • Scene recommendation
    For example, Aqara Agent can recommend a suitable smart home setup based on the current room or use case.
    Example: “Recommend a bedtime setup for the bedroom.”
  • Scene creation
    It is now possible to create scenes through natural language.
    Example: “Create a good-night scene in the bedroom.”
  • Scene snapshot
    You can quickly capture the current device states as a scene snapshot.
    Example: “Capture a scene snapshot of how things are now.”
  • More detailed scene relationship queries
    For example, you can check which scenes are using a specific device.
    Example: “Which scenes use the kitchen lights?”
One additional note: weather support in the current version is not intended for general weather Q&A. It is only used when needed in certain scene recommendation workflows, such as leave-home recommendations.
For automations, the current public capabilities still mainly focus on query, detail lookup, enable or disable, and execution history. Automation creation is not yet part of the current public capability set.
If you have already installed Aqara Agent, you are welcome to update to the latest version in OpenClaw and continue exploring these new capabilities. As always, we would also love to hear what other Aqara Skills or workflow capabilities you would like to see added in the future.
In addition to device logs, scene query and execution, automation query and toggle, automation and scene execution logs, energy statistics, and the additional scene-related capabilities mentioned earlier, Aqara Agent now also supports more automation- and firmware-related capabilities.
  • Automation recommendation
    For example, Aqara Agent can recommend a suitable automation setup based on the current room, device context, and home status.
    Example: “Recommend a bedtime automation for the bedroom.”
  • Automation creation
    It is now possible to create automations through natural language.
    Example: “Create an automation to turn off the bedroom lights every day at 10:30pm.”
  • Device firmware query
    You can now check whether supported devices are already on the latest firmware version.
    Example: “Are all the devices at home already on the latest firmware version?”
  • Device firmware upgrade
    It is now possible to trigger firmware upgrades for supported online devices through natural language.
    Example: “Upgrade the bedroom camera firmware.”
If you have already installed Aqara Agent, you are welcome to update to the latest version of Aqara Agent in OpenClaw and continue exploring these new capabilities. As always, we would also love to hear what other Aqara Skills or workflow capabilities you would like to see added in the future.
