I have three of them one in the living room , bedroom and the front door.
Now the first two clearly get a lot of humans hanging around so have issues and the last one just see people going in and out so no issues with ghosting.
The decided to downgrade the firmware to 1.3.3 to see if this helps address the issue .
The did downgrade one and it was the front door lol
I’m guessing that “The” is actually supposed to be “They,” and he’s probably referring to the Aqara support team.
Anyway, that’s what support did for me—in the background and without me having to do anything.
By the way, I also asked Support whether updating or downgrading the firmware, or editing the map, resets the AI learning process. The answer was no. In case anyone else was wondering!
Well I am keeping editing the map as recently I reset it a few times and made an new map but as I mention sometimes does see some ghosts but also when doesn’t see ghosts the light turn off a bit slowly.but I keep trying to figure it out the best way to make it as I want it.and regarding the AI learning it is stored to aqara cloud in fact every setup of each device it is and when you erase it and add it back all those setups are back too.what would be great is to have access to that data and erase it because sometimes can store some issues or bugs too
If the “AI learning” here really involves a neural network, then data access might be difficult.
I once learned a simplified version of this: for example, you can train a neural network with pictures of a lawn so that it can tell whether grass is visible in the photo or not. And if you always use pictures of a lawn with soccer players in them for AI training, it can happen that the AI learns that a soccer player always means grass. So, if you upload a picture of a soccer player indoors (where there is no grass), the AI will still say it’s grass.
This is simply because it works in a similar way, where synapses have learned to react to certain things in the training data (photos). Modern neural networks have millions to billions of these connections. When the AI makes a decision, it is the result of countless simultaneous calculations across many different layers. What exactly the AI’s synapses reacted to in the photos is impossible or at least very difficult to figure out. It is extremely hard to comprehend why exactly a decision was made, since the whole thing is more like a black box that you can’t just easily look into.
As to whether it can be reset, you could try asking support, and they might also be able to downgrade the firmware for you.
Well we can’t have them all:rofl: ether way I do not need to downgrade was only asking @magnusman60 how he did.as I sad I still learning the fp2 and I still press that AI learning button every time I do things in the kitchen like diner or when the extractor is running on the kitchen so the AI can learn more about the space and be more accurate.to me is not an big issue that sometimes see ghosts as most of the time works perfectly
The other two got downgraded once it was pointed out and the ignoring of the interference zone is gone.
As noted it rarely looses track of a person which i suspect they were trying to fix with 1.3.6 and over did it.
Good news is they are aware and its just a firmware bug which they are working on.
After digging into things further it appears it’s likely not the firmware but the software.
Controls are broken and setting are wont take effect like detection settings.
Setting them from high to anything else wont take and they go back to high.
The app shows presence but once you go into the app itself to see where it shows nothing.
For now using border instead of interference zone works as the interference zone should.
Along with breaking other things it appears they broke the zones during the renaming of some.
Yes that I did notice myself as I reset it yesterday again for the 3th time this week and yeah when you try to change the sensibility from high to medium and yesterday I couldn’t not sure why and today when I check it switched automatically to medium have no idea how more what I did notice that sometime the radar doesn’t detect me and it turn off the light when I move a bit it turns on the light.it looks like it behave like an movement sensor rather then presence detector.
