Hi everyone, I wanted to share my recent experience with the Gledopto GL-C-009 LED dimmer. After some initial challenges with pairing and integration into my deconz setup, I managed to get everything working smoothly. Here’s how I tackled the issue and some tips for anyone else facing similar problems.
When I first paired the dimmer, it appeared in deconz and I could control it via the Level Control cluster. However, it wasn’t showing up in the REST API, which was a bit frustrating. I tried following the advice from the GitHub issue linked by ebaauw, which involved reading descriptors while searching for lights. Unfortunately, that didn’t resolve the issue immediately.
What really helped was resetting the device and re-pairing it. I also noticed that the BASIC cluster fields remained empty, which was a bit puzzling. After some research and troubleshooting, I realized that the device might require a specific sequence of commands or a certain profile setup. I ended up adjusting the pairing process and ensuring all necessary clusters were properly configured.
To assist others who might be facing similar issues, here are some steps I recommend:
Check Logs Thoroughly: Look for any patterns or errors in the logs that might indicate what’s going wrong. Sometimes, the issue is subtle but visible in the log details.
Reset and Re-Pair: A simple factory reset can often resolve unexpected behavior. Make sure to follow the manufacturer’s instructions for resetting the device.
Verify Cluster Configurations: Ensure that all necessary clusters are properly set up and that the device is using the correct profiles and endpoints.
Community Support: Don’t hesitate to reach out to forums or community support. Someone might have encountered the same issue and found a solution.
After resolving the integration issue, I set up a scene where the dimmer adjusts the lights gradually in the evening, creating a cozy ambiance. It’s been a great addition to my smart home setup!
If anyone has questions or needs help with their Gledopto devices, feel free to ask. Happy smart home tinkering! ![]()
