I’ve been using Govee curtains for over a year now, and I must say, they’ve been a game-changer for my home automation setup. The quality and durability are impressive, especially considering how much use they get on a daily basis. However, like any product, they do have their quirks, and I’d like to share some tips I’ve picked up along the way to help others make the most of them.
One thing I noticed early on was that occasionally, one of the curtains would lose power, specifically Curtain 1. It showed as operational in the app, but it just wouldn’t move. I reached out to Govee support, and while they were helpful, it took a few replacements to finally get a curtain that stayed powered. If you’re experiencing similar issues, I recommend trying a soft reset or ensuring the curtain is fully seated in its track before powering it back on.
Another tip I’d like to share is about extending the life of your curtains. I’ve found that adding small fishing weights to the bottom of the curtain helps keep it in place, especially in windy areas. This prevents unnecessary movement and wear and tear. It’s a simple fix that makes a big difference!
If you’re considering upgrading to the Govee Curtain 2, I’d highly recommend it. The design improvements and added features make it even more reliable than the first generation. And don’t worry if you have multiple curtains—you can definitely splice them together without any issues.
Overall, I’m extremely satisfied with my Govee curtains. They’ve transformed my home, and with a little TLC, they’ll continue to do so for years to come. If you’re on the fence about making the switch, I say go for it—you won’t regret it! ![]()
