I recently had the pleasure of setting up my Govee Neon Rope Light, and I wanted to share my experience with the mounting clips. While the process was straightforward, there were a few tips I learned along the way that might help others avoid some common pitfalls.
First, the mounting clips themselves are made of aluminum, which feels durable and sturdy. They come with a strong adhesive backing, but I found that the key to ensuring they hold securely is to place them carefully and press firmly for at least 30 seconds to a minute. I also waited a full 24 hours before attaching the rope light, which was a bit challenging but made a world of difference in terms of stability.
One thing to note is that the clips are designed to be pressed down, not to have the rope forced into them. This might seem obvious, but it’s easy to rush and skip this step. Taking the time to position everything correctly ensures that the clips stay in place and the rope lies flat against the wall.
I also tried experimenting with different patterns for the rope, and I found that keeping the clips evenly spaced made the most visually appealing installation. The aluminum corners are slightly sharp, but I never had any issues with them cutting into the wall or my hands.
Overall, I’m thrilled with how my installation turned out. The neon rope light adds a vibrant touch to my space, and the mounting clips have proven to be reliable and long-lasting. If you’re considering this product, I highly recommend following the instructions closely and giving the adhesive time to cure properly. It’s a small detail that makes a big difference!
Happy lighting!
