Govee RGB Light Strip Review and Automation Tips
As a long-time fan of Govee products, I’ve always been impressed by their ability to combine style and functionality. Recently, I had the pleasure of testing out the Govee RGB Basic 32ft Strip, and I wanted to share my experience and some tips on how to integrate it seamlessly into a smart home setup.
The Unboxing Experience
Unboxing the Govee RGB strip was a breeze. The packaging was simple yet sturdy, and the included components were clearly laid out. The controller is compact and sleek, which makes it easy to mount in tight spaces. The 12-watt power supply, while smaller than some other Govee models, does come with a right-angle design, making it easier to hide behind furniture or along walls.
Installation and Setup
Installation was straightforward. The strip is a single 10-meter length, which is great for longer runs without the need for additional connectors. The 3M adhesive backing worked well, and the strip stayed in place without any issues. One minor downside is the lack of clips, so I had to borrow some from my existing setup to ensure the strip stayed flat and aligned properly.
Brightness and Color Quality
While the brightness isn’t as intense as some of Govee’s other strips, it’s more than sufficient for accent lighting. The white light has a slight blue tint, which isn’t ideal for task lighting but works perfectly for creating a warm ambiance. The RGB colors are vibrant and rich, making it a great choice for mood lighting or adding a pop of color to a room.
Automation Integration
One of the standout features of this strip is its compatibility with smart home automation. By pairing it with a Govee Smart Plug, I was able to control the strip through my Alexa and Google Assistant routines. This integration allowed me to set up scenes that automatically adjust the lighting based on the time of day or my activities. For example, in the evenings, the strip transitions from a cool white to a warm amber, creating a relaxing atmosphere.
Tips for Maximizing Your Experience
  1. Use Clips for Neat Installation: While the strip comes with an adhesive backing, using clips ensures a neater and more professional-looking installation.
  2. Experiment with Scenes: Don’t be afraid to create custom scenes in the Govee app. You can set up different color schemes for different times of the day or moods.
  3. Combine with Smart Plugs: If you don’t want to deal with physical controls, pairing the strip with a smart plug adds an extra layer of convenience and integration with your smart home ecosystem.
Conclusion
Overall, the Govee RGB Basic 32ft Strip is a fantastic addition to any smart home. Its combination of affordability, ease of installation, and compatibility with smart home systems makes it a top choice for anyone looking to enhance their home’s lighting without breaking the bank. If you’re in the market for an RGB strip that’s both functional and stylish, I highly recommend giving this one a try!
#Govee SmartHome #RGBLights HomeAutomation
