Govee products have consistently impressed me with their quality and innovative design, and the Govee Tower Fan 32" is no exception! After using it for a while, I decided to give it a deep clean and some maintenance, and I’m thrilled to share my experience.
I started by unplugging the fan and letting it cool down completely. The design made disassembly surprisingly straightforward—no hidden screws or complicated steps. All the screws were easily accessible, and the intake cover came off without any hassle. I used a soft brush to gently clean the blades and motor, making sure to avoid any rough scrubbing that might damage the finish.
For lubrication, I used white lithium grease, which worked perfectly. I applied it with a q-tip to the spinning points, ensuring a smooth application without any excess grease. Reassembly was just as simple, and I was amazed at how much quieter the fan runs now. It’s like having a brand new unit!
One thing I noticed is how well-balanced the fan is. Even at higher speeds, it doesn’t wobble or make any unwanted noise. The oscillation is smooth, and the different speed settings make it versatile for any room. Plus, the sleek design blends seamlessly into my decor.
If you’re considering this fan, I highly recommend giving it a thorough clean and maintenance session. It’s a small investment of time that pays off in performance and longevity. Let me know if you’d like more tips or have any questions about maintaining your Govee products!
Happy cooling! ![]()
