GPIO Voltage Level Adjustment for OLED Display Integration
Hello everyone,
I recently came across an interesting challenge while working with the nrf54L15-PDK development board. I wanted to integrate an OLED display into my project, but I encountered an issue with the GPIO output voltage. The board’s GPIO pins were providing a 1.8V output, which wasn’t sufficient to power the OLED display properly. This was quite frustrating because the supply voltage for the board is 5V, so I expected the GPIO pins to output a higher voltage.
After some research and experimentation, I discovered that there might be a way to configure the GPIO pins to output a higher voltage. I reached out to the Nordic Semiconductor community to see if anyone had encountered a similar issue and could offer some guidance. Thankfully, I received some helpful responses that pointed me in the right direction.
One user suggested checking the board’s documentation to see if there were any configuration settings or registers that could adjust the GPIO voltage levels. I dove into the datasheet and found that the GPIO pins can indeed be configured to output higher voltages, but this requires modifying some low-level settings. I wasn’t entirely sure how to proceed, so I decided to test a few configurations carefully to avoid damaging the board.
After some trial and error, I managed to adjust the GPIO voltage settings, and the OLED display started working as expected! It was a great feeling to overcome this obstacle and learn more about the board’s capabilities. This experience taught me the importance of thoroughly reviewing documentation and not being afraid to experiment when working with hardware.
If anyone else is facing similar issues with GPIO voltage levels, I’d be happy to share the steps I took to resolve the problem. Feel free to reach out with any questions or suggestions!
Cheers,
