I have posted about the use of the Aqara app and in that post referred to difficulties with the Aqara H2 UK Smart Plug. I thought it better to post this as a separate subject.
I bought a pack of 3. Call them “1, 2 & 3”. Initially it was a struggle to set them up. One in particular, number 3, needed several attempts. Once installed in the app I then connected them to HomeKit. Initially it seemed OK, but number 3 proved troublesome. It did not seem to want to be seen and could not be found in the system. I swapped it for No. 2. That seemed to be OK but then I found it had switched off. It may have been me catching the large icon in the app which would turn it off. I don’t know. The app could see the other two. Sometimes. Not always.
As the app is quite cumbersome to use I decided to delete them and install them only in HomeKit. Doing a reset was not easy. The quick twice press and then hold did not do anything. I did the factory reset. Press the button 10 times. Again, at first it did nothing until I found you need to press the button very quickly.
Having reset I yesterday installed in HomeKit again. They appeared to be there and operating. Number 3 was used to switch on a PSU. It operated fine yesterday. This morning I went to switch it on remotely and HomeKit could not see it at all. I had not switched off power to it. Switching it on manually and HomeKit still did not see it. I swapped it for number 2 as it appeared to be working. Plugging in number 2 and HomeKit did not see it until I stimulated it by pressing the button to turn it on, off and then on. Plugging number 3 into a spare socket and HomeKit still could not see it despite my not having removed it.
I cannot rely on these when operation is hit and miss. One in particular seems to have issues. Consequently, I have reverted back to a spare Philips Hue Smart Plug. I have used their product for some years and never ever had issues of this nature that I am having with Aqara.
At present I have left one of the three plugged in to a spare socket doing nothing and will monitor it to see if the system continues to see or if it drops out. If all good I will go back to using it.
Does anybody in the forum have any suggestions? Indeed, does Aqara know if issues have surfaced with some of them?
