Greetings, fellow智能家居 enthusiasts! I’m reaching out to share my experience and seek some guidance regarding my Z-Wave setup using Habmin1 on my Raspberry Pi. It’s been a fascinating journey, but I’ve encountered an intriguing challenge that I’m eager to resolve.
I’ve successfully configured my Z-Wave network using Habmin1, and everything seems to be running smoothly—controller identification, exclusion, and inclusion processes are working as intended. However, I’ve noticed an issue with the node numbering system. After several inclusion and exclusion operations, the node numbers accumulate and start from the last factory reset point. This makes it increasingly difficult to keep track of the nodes, especially as my network grows.
I’m curious if there’s a way to perform a factory reset directly within Habmin1 to reset the node numbering. I understand that a factory reset would clear all existing nodes and start fresh, which would simplify network management. I’ve tried searching for solutions within the Habmin1 interface and online forums, but I haven’t found a clear method yet.
If anyone has encountered a similar situation or has insights into how to manage node numbering more effectively, I’d be grateful for your advice. I’m particularly interested in whether a factory reset can be initiated through Habmin1 or if there’s a workaround to reset the node numbering without losing all my configuration settings. Your expertise would be invaluable!
Thank you in advance for your time and assistance. Let’s continue to explore and optimize our smart home setups together!
Best regards,
