Hassio Installation Troubleshooting on Archlinuxarm
Has anyone else faced issues installing Hassio on Archlinuxarm? I ran into a problem where the installation failed due to a version conflict with PyYAML. The error message indicated that the current PyYAML version was incompatible with Home Assistant’s requirements. After some research, I found that downgrading PyYAML to a version below 4 but at least 3.13 resolved the issue. Here’s how I did it:
  1. Uninstall the current PyYAML using pip3 uninstall pyyaml.
  2. Install the specific version using pip3 install pyyaml==3.13.
  3. Re-run the Hassio installation command.
This worked like a charm! If anyone else is struggling with similar issues, I recommend checking your Python package versions and ensuring they align with Home Assistant’s dependencies. Happy installing! :rocket:
