Ok sorry if I have posted this in the wrong area , however I am reasonably new to Aqara , having recently tried a couple of products and like them so have decided to expand more Aqara into my home.
I have a relatively complexed situation and am having difficulties in getting them all to play nicely .
Home 1 ( Aqara M3 + multiple devices + Apple Home + Homey Pro + Alexa as well as other hubs such as SmartThings and Hue )
Home 2 ( Apple Home , Tapo home base + Alexa )
Home 3 ( Aqara G3 camera hub + G410 Doorbell )
Ok so the crux of the matter is that I needed to put in a smart doorbell in home 3 ( and I will be wanting to do the same in home 2 as well at some point ) so as I was investing in the Aqara products I thought I would use this as a tester for future expansion , I read that you could bridge 2 Aqara hubs on different WiFi networks , so I purchased the G3 security camera as well although I now realise the g410 also has a built in hub , although I didn’t really need an internal security camera I thought it would be handy to have a duel usage product and I didn’t really want to spend money on a M3 hub just for 1 device or did I want to buy an Apple TV or pod for a home server as neither of them would be used for anything but the Apple hub part .
Installed the g410 and G3 in home 3 and connected to the Aqara App and all is hunky Dorey , although I still need to play with them to set them up correctly as I am gettimg pinged every few minutes with notifications , and Aqara setup doesn’t seem be as easy as Tapos for AI face recognition etc but that’s another story .
I read that once I returned to Home 1 I could bridge the two hubs onto the M3 , the reason I wanted to do this is so I could see the cameras in Apple Home as a central location for viewing security cameras , doorbells etc and the M3 is bridged to Homey Pro and Apple Home and there for see feeds and alerts on my TV or other devices .
Homey Pro works well with Aqara but won’t work with any matter cameras including Aqara and so I’m left with Apple Home as a central hub.
I tried to bridge the G3 and the M3 with no success so Apple can’t see the external devices/cameras , I read you had to merge/migrate the two hubs together onto the M3 which I did , but all that happened there is it deleted my G3 from the app altogether , luckily I had someone going to home 3 so I gave them Aqara permissions and they re-added the device to the app.
The M3 hub now seems a bit flakey after the migration of the G3 hub , network errors and such , but seems to be generally working .
So basically I need the M3 hub to see both the devices in Home 3 so I may bridge them to either Apple home or Homey Pro .
Any ideas anyone ?
And sorry for the wall of text
